Closer and closer / blower build
Old Feb 22, 2006 | 02:27 PM
kdcollins's Avatar
kdcollins
Default Closer and closer / blower build
the engine is assembled, I am now "fitting" all accessories for proper fit before installation.
Old Feb 22, 2006 | 02:28 PM
ylose's Avatar
ylose
Default Nice EYE candy !
She is real Purdy !
Old Feb 22, 2006 | 06:49 PM
Z-man's Avatar
Z-man
Wow!
Old Feb 22, 2006 | 08:02 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Old Feb 22, 2006 | 09:22 PM
panchop's Avatar
panchop
curious to see what your solution is for your water pump outlet and belt. just relized i ight have a little problem with my setup.
Old Feb 22, 2006 | 09:25 PM
76custompaint's Avatar
76custompaint
Sweet looking engine, what are the specs of it? (heads, rods, pistons etc etc..)
Old Feb 22, 2006 | 10:00 PM
kdcollins's Avatar
kdcollins
I installed the water pump and alternator tonight to check for alignment. I had to shim the crank pulley, idler pulley bracket and blower pulley about 1/4". After that, the water pump and alternator lined up. I have not tried the power steering yet, that will be the mission for tomorrow night.
4.030 x 3.48 bore & stroke
-21cc dome forged pistons
5.7 rods
.464 int/.464 exh lift
.222 int/.226 exh @ .050 dur
114* lobe sep
2.02 int/1.6 exh - 64cc chambers - 200 runners, aluminum heads
6-71 blower w/2 - 600 Holleys
Old Feb 22, 2006 | 10:34 PM
Maine Vette's Avatar
Maine Vette
Hey, is that thing in your living room!
Looks great!
Old Feb 22, 2006 | 10:53 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
That's been my biggest headache, no aftermarket water pump pulley I tried lined up with the crank and alt. pulley. Ended up using a stock waterpump pulley. One of the problems I've found is the grooves in the crank pulley are closer together than those on all the water pump pulleys. Had to use a 1/4" spacer behind the driven blower pulley also.....
Old Feb 22, 2006 | 11:06 PM
panchop's Avatar
panchop
my problems a little differnt. Iwent with an electric pump but if you look you can see that the water pump outlet ( about 7 oclock )will point right into the blower belt.
Old Feb 23, 2006 | 08:07 AM
kdcollins's Avatar
kdcollins
Looks great!
Thanks!
They give me the basement and keep the upstairs for themselves. It is a good araingement.
So far, it looks like the waterpump outlet is going to be ok. The thermostat housing outlet, however, might be a little different story. I did purchase a thermostat housing relocation kit just incase this was an issue. We'll see if I need it.
Old Feb 23, 2006 | 08:45 AM
norvalwilhelm's Avatar
norvalwilhelm
Why Panchop are you having a problem. Running the accessories out front makes it easy.
I might still have a waterpump pulley, a billet one that is correctly spaced for the front take off of the accessory belts.
Forgive the old messy picture.
I have run it exactly like this since 1999
Old Feb 23, 2006 | 08:48 AM
norvalwilhelm
Panchop I like those headers. Are they for side exhaust?
Old Feb 23, 2006 | 10:37 AM
panchop's Avatar
panchop
nah, they are not corvette headers. they where built for a BBC Monza drag racer. just have them on to run on the run stand we are building. i will figure some kind of plumbingsystem out this weekend. i am having the same thermostat problem as KD.
Old Feb 23, 2006 | 12:09 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Hey guys, the Weiand manifold looks like the thermostat is mounted in the same location as my Holley 420 Megablower. I don't have the part number of the housing that was supplied with mine, but I'll bet Summit has it. It will get you around the belts like so....
Old Feb 23, 2006 | 01:51 PM
norvalwilhelm
I never had an issue with the thermostat housing. I used the exact same one as on my nitrous motor and with the pulleys out front it isn't even close.
To Closer and closer / blower build
