I am beginning to think of a new engine for my '72 vert,
SB, base engine. Use is strictly street/cruise.
What makes more sense, crate, like a ZZ4, or rebuild
the equivalent? BB is not an option.
After pricing out a total rebuild from the bottom up, I chose the crate route. So, you pay a few more bucks, but you are paying for research, develppment, and properly fitted components. I think my crate only ended up costing about 500 more than doing a rebuild I priced out. And check around on crate motors. Many better buys better than the zz4 as far as bang for the buck. Try this........http://www.blueprintengines.com/index.html
Two local machine shops quoted me $700 to machine my block
The rotating assembly is less than $900 (Scat or Eagle, nodular crank, hypereutectic pistons, rods with ARP bolts, balanced aso). A 4-bolt main short block is about $1300 - $1600, depending on internals. A 383 short block is not more expensive than a 350.
I'd buy a short block, re-use your heads or buy better heads if you want more HP.
Depends on how original you want to keep it. If you are going to make a daily driver, I would go with one of the crates with TPI and also install the Termec transmission http://www.classicchevy5speed.com/68..._Selection.htm
If you want to keep it stock, then rebuild is the only way to go. Also depends on how much you have to spend.
im doing a rebuild right now. But I didnt want to mess up my numbers matching stuff. So i was just going to buy an engine from scratch. It is my first rebuild and so half the reason im doing it is for the experience. I got lucky and scored a short block that had a forged crank, rods and pistons for 500 bucks. All the parts checked out good, so I saved MASSIVE amounts of cash on that one...now all i have to do is get the top end.....then theres the while im at its....
My friend however did his from scratch and did not run into any deals like I did and his 383 ended up costing him about 3500 bucks. It is a very mild build an only puts out about 350 horsepower. If he were to do it over again he told me he would definitly go the crate motor route. Lot less headaches, and you can be sure the motor will work when you crank it.
For your application I would go with a crate. You can probably build it a bit cheaper, but for the time factor and you will get a 1-pc rear seal on GM crate motors (except the "Targetmaster" 350) I would store your original engine for posterity and drop in a crate.
