Is this a 68 part? It is a left lower dash light bracket. I saw some C3s use a separate little bracket but saw this one and like to know if anyone knows what year this part was used, http://cgi.ebay.com/ebaymotors/ws/eB...tem=4612267442 Thanks AL.
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
yeah thats it alright, better than having the bulbs just hand down or strapped in place
Tim, any idea when they used this type bracket? I've mostly seen the small screw on ones like the use on the passenger side, AL.
your guess is a good as mine with some of these older cars, hell it may be a hafl year 68 thing like the rest of the stuff in my car. Let me know if you want a list
Tony, Thanks!!! This is one of the part changes in 68. My 68 was build 4/29/68 and had a bracket just like the one you sent but did not have the light holder on the bracket just the reset cable holder. I did buy one like you sent because I didn't want to use a separate light bracket to hold the light, AL.
tim
Tim, thanks but I've owned mine for over 20 years and it has drove me nuts because I have a mix of new and old design parts on mine from the factory , AL.
Yeah i have found both early and late 68 parts from my car i know it came from the factory with. i have been able to find everything except the smooth finish gauge cluster. every one ive seen is pebble finished even at my local corvette junk yard.
Hmmm, my 68 vert didn't have the bulb holder either on the reset bracket. There was a separate bracket, similar to the rear compartment light bracket. Which is correct?
They both very well may be depending on what day the car came down the line. lets just say 1968 manufacturing practices were not neccesarily an exact science. especialyy since it was the first year of the body style.
Ill keep looking though
you never know when youl get lucky
tim
Whats wrong with yours, The top corner broken? AL.
My November 67 build date car did not have the bulb holder.
My 68 has the the trip reset bracket with light on the driverside. The passengerside and rear compartment light brackets are the same.
Bryan
This is not how mine was from the factory because there is a bracket there with out the lamp holder and hole on the bracket that was maybe for the separate lamp holder. I did like the idea of having the one bracket holding the lamp and the reset cable so I did buy one, I like to know when the combination bracket was used and the separate lamp holder was used (was this a convertable/coupe thing?). AL.
