Msd6al
Old Feb 24, 2006 | 08:10 PM
71redskin's Avatar
71redskin
Default Msd6al
wife asks what i wanted for our 13th anniv. i think i wanna get msd box and blaster2 coil...any of you guys have pics so i can see where you installed yours. i have a 71BB if it matters..
Old Feb 24, 2006 | 08:43 PM
commando57's Avatar
commando57
Mine is behind the passenger fender. The red coil will match your car.
Old Feb 24, 2006 | 08:49 PM
ZL1powr's Avatar
ZL1powr
I mounted mine on the front of the radiator support behind the front grill on the passinger side. Gets plenty of cool air. Been there for about eight years with no problems.
Old Feb 24, 2006 | 08:53 PM
rcread's Avatar
rcread
Mine is in front of the radiator support, off to the side. I'd take a picture, but you can't really see it. It's been there for about eight years and works fine.
Old Feb 25, 2006 | 09:17 AM
71redskin's Avatar
71redskin
so the wiring kit that you get with it will work from there. did you also install the vibration eliminator
Old Feb 25, 2006 | 11:20 PM
b71vette's Avatar
b71vette
Default I would recommend the MSD
Blaster High Vibration Coil over the Blaster 2. Blaster 2 is oil filled and susceptible to burning out the coil winding if it is not mounted vertically with no slant. the MSD High Vibration is filled with an epoxy I believe and is more durable. Only about $10 difference in price.
Jeg's part# 121-8222
For circle track, off road and other severe duty racing applications, this is the coil! The windings of the High Vibration Coil #121-8222 are completely encased in a premium epoxy making it impossible for vibration to affect the windings. This assembly is housed in a unique alkyd molded shell which provides high dielectric characteristics plus a very durable shell. Brass primary terminals ensure full voltage delivery and are spaced far apart to eliminate the chance of spark arc-over. The High Vibration Coil can be mounted in any position and can be used with a standard canister coil mount.
Old Feb 26, 2006 | 12:58 AM
JPhil's Avatar
JPhil
My 6A box is on the passenger side fender well above the a-arm. Had to get the distributor extension wire loom to reach.
Old Feb 26, 2006 | 12:36 PM
redc3's Avatar
redc3
unless you running nitrous, skip the box and install the msd e-curve billet dist. no box, no weights or springs, smaller than hei, built in rev limiter. its a no brainer
Old Feb 26, 2006 | 12:44 PM
Jims79's Avatar
Jims79
I don't know but do you think she was talking about a present for the vette or what she wanted for your 13th anniv? You better be getting 13 long stems and a ring for her or you maybe sleeping in the vette.
Old Feb 26, 2006 | 11:23 PM
ZL1powr's Avatar
ZL1powr
I ran my own wires and yes I used the vibration pads.
Old Feb 27, 2006 | 02:34 AM
Z-man's Avatar
Z-man
I put mine (blaster coil & MSD digital 6 plus) on the passenger side wheel well below/behind the radiator expansion tank. Can't see it in the photo, but the coil is on the firewall across from the windshield washer can. I can get to these by removing the grill behind the wheel. (That's my Ford remote starter solenoid...)
Old Feb 27, 2006 | 10:47 AM
71redskin's Avatar
71redskin
well i know she was talkin about what i wanted. if she asks that she knows its gonna vette or golf related. long stems is a definite and i've done things in a vette that they weren't designed to be done in... sleepin would be ez..
To Msd6al
