What would you do??
Old Feb 25, 2006 | 12:22 PM
Wuttin's Avatar
Wuttin
Default What would you do??
Hey folks...some cosmetic issues that need attention before the season...
Rust on chrome rims
Peeling chrome on spokes
Bad clear coat around emblems, nose and gas cap
For now, changing the wheels is not an option...maybe in 2007. I'd like to make them presentable until then. Wheel shop says they're perfectly safe, just look lousy.
Many thanks,
Steve
Old Feb 25, 2006 | 12:46 PM
stingraymaniac's Avatar
stingraymaniac
blast and paint the wheels,maybe a black center and silver around?
repaint the gas cap the nose dosent look so bad
Old Feb 27, 2006 | 12:53 PM
Wuttin's Avatar
Wuttin
Best to strip it and start fresh, I'm guessing. Any details on steps and recommended materials greatly appreciated:
    Old Feb 27, 2006 | 02:12 PM
    Scottys78's Avatar
    Scottys78
    As far as your wheels go…….I would take a piece of steel wool and use it on the rust spots……..that should take care of that. The Gas cap is easer to fix b/c you can remove it, take the badge off and repaint the whole cap. If I were you I would also think about new badges too. The nose badge I would leave alone until you are ready to repaint the whole car. That’s just my two cents.
    Old Feb 27, 2006 | 04:23 PM
    Wuttin's Avatar
    Wuttin
    Thanks...any details on types of paint?
    Old Feb 28, 2006 | 09:24 PM
    72LS1Vette's Avatar
    72LS1Vette
    AutoZone sells an aircraft stripper that will take the clear coat off quickly. You can then polish the wheels and apply a new clear coat. Polishing is labor intensive but you should be able to get a couple more years out of the wheels.
    Rick B.
    Old Feb 28, 2006 | 09:37 PM
    rihwoods's Avatar
    rihwoods
    Did they put clear coat on chrome wheels ?
    Old Mar 1, 2006 | 12:23 AM
    TonySinclair's Avatar
    TonySinclair
    Pep Boys...$29.99:
    Old Mar 1, 2006 | 02:55 AM
    Demonic Possession's Avatar
    Demonic Possession
    Rust wise, my rims were in as bad of a shape or even worse than yours. They haven't been touched in over 20 years. I used some turtle wax chrome polish and some elbow grease and they came out pretty good. On the area with alot of rust on it, just keep going at the area and keep adding the chrome polish to it. So some harder spots, I would leave it one for 20-30 mins. I'm serious though, it should take you a couple hours per wheel. I also had some peeling chrome,but not as bad as yours. I just left it alone, because I don't think there's anything else you can do to it other than get it rechromed. I was then going to get that mother's ball thing and use that on the rims after I polished them inorder to clean them up better but I decided to focus on the engine first.
    Here are my pictures . I had better detailed ones, showing before/after but I lost those pictures after my computer crashed. So these are the only ones left.
    Old Mar 1, 2006 | 03:01 AM
    Demonic Possession
    Sorry, repost.
    Good Luck with your rims
    Old Mar 1, 2006 | 10:46 AM
    72LS1Vette's Avatar
    72LS1Vette
    Hard to say. Unless I'm just seeing reflections in the picture it looks like there is some whitish corrosion on the spokes. I was going to suggest that they were polished aluminum with a clear coat, but since there is rust they must be steel. A tiny dab of the stripper would tell for sure. It shouldn't affect the chrome but if the finish bubbles right away there is a clear coat on the wheel.
    BTW, DON'T use the aircraft stripper on the gas lid. It will take all of the paint off, not just the clear. If the edges of the clear coat on the lid are feathered down, a few new coats of clear should improve the appearance quite a bit.
    Rick B.
    Old Mar 2, 2006 | 09:12 AM
    Wuttin's Avatar
    Wuttin
    Your pix are encouraging! I'll take your advice and tackle the rust then go after the peeling chrome. I'm thinking of sourcing some self stick laminate that I can cut and attach to the spokes instead of trying to paint the offending areas...TBD. Any leads or thoughts on this approach?
    http://www.alsacorp.com/products/sal...inates_spk.htm
    http://www.tape-works.com/Default.htm
    Thanks again,
    S
    Old Mar 2, 2006 | 10:22 AM
    72LS1Vette's Avatar
    72LS1Vette
    I've seen Chrome paint at AutoZone and I believe Eastwood sells some also. That might work. I would think that the stick-on stuff would be hard to apply without wrinkles. It is possible to paint over chrome if you sand the surface enough to dull it. The paint probably wouldn't last as long as it would if applied over bare metal, but it might get you throuhg until you can buy new wheels.
    Rick B.
    Old Mar 2, 2006 | 11:35 AM
    Jims79's Avatar
    Jims79
    Time for new wheels, those old keystones are toast. The paint you can take to a local body shop for touch up repair.
    To What would you do??
