Trailing arm dissasembly
Old Feb 26, 2006 | 06:55 PM
chris73cpe's Avatar
chris73cpe
Default Trailing arm dissasembly
I'm sure this has been asked before, but I couldn't find anything helpful by searching. How do you get the spindle support off the trailing arm? It's already off the car and the 4 nuts are off, but I can't get it to budge. I've tried prybars and trying to drive a chisel between the 2 with no luck. I don't have a press, but I'm leaning towards picking one up from harbor frieght because it seems like every part on this car is pressed together.
Old Feb 26, 2006 | 08:12 PM
GWell78's Avatar
GWell78
Do an advanced search using "Trailing Arm" and specify C3 Tech/Perf and you'll get plenty of threads. I did this to read up before I started mine this weekend. You'll need a press for this job if you do it yourself.
Old Feb 26, 2006 | 08:19 PM
ckerch's Avatar
ckerch
Make sure you get the 20 ton press. I picked up there 20 ton and it work great. From what I understand , anything less is questionable for removing the bearing and press out the spindle.
Checkout this thread . It was very helpful when I did mine.
Carl
Old Feb 26, 2006 | 08:20 PM
chevy69's Avatar
chevy69
St. Jude Donor '08
I took mine to a shop to have them pressed out, along with the bushings.
Old Feb 26, 2006 | 11:08 PM
chris73cpe's Avatar
chris73cpe
I've been reading through a ton of gary's threads too, you really can't ask for better info.
I was actually looking at the 12 ton press, thought that would be more than enough. Anyone know for sure if that's not enough for what I'm doing?
To Trailing arm dissasembly
