what should it cost
Old Feb 26, 2006 | 09:04 PM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
Default what should it cost
for a mechanic to remove the heads and intake and replace the gaskets> I suspect thats where my vacuum leak is.
Old Feb 26, 2006 | 09:12 PM
canucbuck's Avatar
canucbuck
My guess would be 8 hrs. at $60.00 hr.= $480.00 + gaskets.
73sbvert's Avatar
73sbvert
Crackin' on...
St. Jude Donor '09
Before you go into all that expense (and it will depend solely on YOUR mechanic's abilities and shop policies), I would seriously recommend getting a can of starting fluid (available at most car parts stores) and using the spray tube, go over all of your vacuum lines (and there are a LOT of them!) and their respective connections by lightly spraying them. Wherever there is a leak, the engine speed will go up noticably, and that will pinpoint it.
I can't imagine that a head gasket will cause a vacuum leak, not without other indications anyway.
What are your symptoms?
Old Feb 26, 2006 | 09:24 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
its about $80 hr at a vette shop..
Old Feb 26, 2006 | 09:25 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
It whould be a blown head gasktet then? Check the compression of each cylinder.
Old Feb 26, 2006 | 09:39 PM
SIXFOOTER's Avatar
SIXFOOTER
There is no vacuum on the heads except for the intake/head connection. If you have a vac leak it will be there, or carb base gasket if on the engine. There is a Bunch of hoses where it will more likely be leaking. The start fluid test is a good one to use to find the leaks.
What are the symptoms indicating a vac leak?
Old Feb 27, 2006 | 01:45 AM
Supersportt396's Avatar
Supersportt396
Default Leak
I dont think you would get a leak from the heads. Intake to heads yes but save yourself some cash and let a pro check it out. I wouldnt use starting fluid to check for a leak, you may end up with a bigger problem as in a fire, I would use carb cleaner and be very careful with it also. JMHO
Old Feb 27, 2006 | 04:27 PM
71rdster's Avatar
71rdster
+oil and antifreeze, and disposal charges
Old Feb 28, 2006 | 01:26 AM
lowbuck72's Avatar
lowbuck72
One way to check for vacuum leaks is with a bottle of propane. Spray a little propane (unlit) near the source of the suspected leak while the engine is running. The idle speed will increase if there is a leak. (the propane is sucked into the engine and consumed as fuel).
Old Feb 28, 2006 | 01:30 AM
rihwoods's Avatar
rihwoods
Intake alone could cost around $300 +
To what should it cost
