Man do I need help, suggestions or recommendations!
Old Feb 28, 2006 | 08:15 PM
Rick Church
Guest
Posts: n/a
Default Man do I need help, suggestions or recommendations!
I'm trying (as a novice) to do my own brake caliper (all four) replacement. While I'm in there, I'm replacing the rear leaf spring, cleaned the rear end area, replacing the rear parking brake cable and hardware, all four shocks, and parking brake system in the rotors. I enjoy it but have run into some real problems I need help on. I'd like some advice on the following:
1. The rear shocks upper mounting bolts are frozen and I can't seem to get them loose. The 11/16 nut is positioned such that I can't get a wrench on it to apply any leverage (cross member is in the way). I have used WD40 a lot! The head and nut seem frozen with rust. The shocks don't leak, they're just old and I'm frustrated to the point of leaving them on the car but I've already bought new ones. How do I get these darn bolts and nuts loose (both sides of the car)
2. I'm replacing the parking brakes with SS parts and shoes; the small pin (rear, driver's side of the car) that the spring fits over can not be removed without removing the large backing plate. Can I remove the plate enough to get the old pin out and a new pin in without removing the wheel hub assembly?
Right now I'm at a work stoppage with these issues and I'd sure appreciate some help from you guys that have gone through this before.
Thanks in advance,
Rick in Tennessee
Old Feb 28, 2006 | 09:03 PM
sly vette's Avatar
sly vette
Get a die grinder and cut the head of the bolt off. As far as the pins for the E-brakes go, you can leave the old pin in and use it, or if the old bolts are'nt too rusty you can access the pin after you remove them. I will be willing to bet that the large bolt on top will be difficult. If you do gain access to the pins, after inserting them, apply some silicone to the head of the pins, tie some string to the tip of the pins and wrap the other end of the string around a wheel stud. that way the pins will not move as you are trying to install the retaining springs. Before you try to install the retaining springs, compress them, and tie them with dental floss. It will be much easier to install them that way. Have patience ,the E-brake job can be a bear!!!
Later,
Sly
Old Feb 28, 2006 | 09:05 PM
pcfred's Avatar
pcfred
St. Jude Donor '05
PB Blaster for the rusted bolts, blast and let soak, blast and let soak.
Old Feb 28, 2006 | 09:38 PM
72LS1Vette's Avatar
72LS1Vette
WD40 was not intended as a rust solvent. It was developed as a Water Displacement spray for the military (apparently the 40th revision worked). I have had very good results with PB Blaster. If you have the time, spray some PB on every day for a week. Try the fastener every day to see if it is freeing up. The only nuts I haven't been able to remove with PB are the ones that are rust-welded onto the bolts. If the nut starts to move, work it back and forth slowly to free it up.
There is another solvent named Kroil that is supposed to be even better than PB but it isn't as easy to find.
Good luck and don't try to rush things too much.
Rick B.
Old Feb 28, 2006 | 09:43 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
Later,
Sly
sly i can 't believe you are misleading the guy like this.......the E-brake job IS a bear!!!
Old Feb 28, 2006 | 09:50 PM
72-LT1's Avatar
72-LT1
My top shock bolt was rust welded to the inside sleeve, just another thing that needed to be cut off.
Old Feb 28, 2006 | 09:58 PM
Edzred72's Avatar
Edzred72
[QUOTE=Blair Winch ProjectThere is another solvent named Kroil that is supposed to be even better than PB but it isn't as easy to find.
Rick B.[/QUOTE]
Kroil available through Eastwood.
Rick Church: (P-brake shoe pins) As mentioned above, you can take the 4 or 5 small bolts out that attach the brake shield, then loosen the big one at the top center just enough (spindel will prohibit complete removal) to tip the brake shield and remove/install the new stainless pin. Before installing the shoes, put a glob or RTV where the pin meets the shield and let it dry. This holds the pin in place. Compress the shoe retainer springs and tie them up compressed. This helps get the shoe and shoe retianes on. When all is installed...cut/burn the string off.
This article might help you some.
http://www.rowleycorvette.com/corvette_repair.html
Eddie
Old Feb 28, 2006 | 10:02 PM
Edzred72's Avatar
Edzred72
BAAHHHH... just takes patience, opperating room type instraments and steady hands.
Eddie
Old Feb 28, 2006 | 10:07 PM
bobs77vet's Avatar
bobs77vet
Eddie
again more mis information.....you forget the dictionary of swear words.....and you better do this with a really good friend or you guys will never to speak to each other again
Old Feb 28, 2006 | 10:16 PM
Edzred72's Avatar
Edzred72
OR...get your friend so drunk he won't remember the nightmare.
Eddie
Old Mar 1, 2006 | 10:12 AM
sly vette's Avatar
sly vette
[QUOTE=bobs77vet]sly i can 't believe you are misleading the guy like this.......the E-brake job IS a bear!!![/
Actually it can be alot of fun... Depending on your definition of fun...
Old Mar 1, 2006 | 10:31 AM
mooneyd's Avatar
mooneyd
Rick B.
Forget the WD40 Good luck
Old Mar 1, 2006 | 11:07 AM
marks68's Avatar
marks68
Rick B.
www.kanolabs.com
The only way I have found it is directly from the company on line. This stuff is freakin' magic. I haven't had one bolt that I couldn't get out when using it.
Old Mar 1, 2006 | 03:36 PM
Jims79's Avatar
Jims79
Eddie
don't do it yourself, that's a big project you took on. most guys who know what they are doing would do one at a time. Get a friend or make one who knows what he's doing and likes free beer.
Keep us up to speed.
Old Mar 1, 2006 | 03:58 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Take it to a garage and put an air gun on it....why struggle.
Old Mar 1, 2006 | 04:15 PM
bobs77vet's Avatar
bobs77vet
you know those father/son bonding moments.....we had two of those.... for each of the two nights we worked on replacing the Parking Brakes......
To Man do I need help, suggestions or recommendations!
