Spare tire carrier
Old Mar 1, 2006 | 01:00 PM
71stockray's Avatar
71stockray
Default Spare tire carrier
What is the interchangability of spare tire carriers? In other word what years will fit a 71? Will a 74 fit? Thanks, Guys
Old Mar 1, 2006 | 01:06 PM
bluesilver82's Avatar
bluesilver82
Correct me if I am wrong but I think 68-82 are the same and can be interchanged.
Old Mar 1, 2006 | 02:34 PM
Xakk's Avatar
Xakk
Well, I know earlier C3s had full sized spares and later had donuts. I'm pretty sure my 81 won't fit a full sized tire and rim, so I'm assuming they'd be different. But I don't know where the cut off is.
Old Mar 1, 2006 | 03:06 PM
halfmoontrail's Avatar
halfmoontrail
I've heard '68-'78 for spare tire carriers
Old Mar 1, 2006 | 09:45 PM
kdf1986's Avatar
kdf1986
Hello
When I bought my 72 it did not have a spare tire or a tire carrier. I bought a used one from a 1976 at the local junk yard for $50.
There is an upper piece ( $70 repro) and a lower tray ( $165 repro)
The lower tray is held in place in the back by two long bolts. The front of the tray is held in place with a long bolt and nut to pull it tight.
kdf
Old Mar 2, 2006 | 02:49 PM
spikezz4's Avatar
spikezz4
Default Spare Tire Carriers
We'll be using a C4 carrier (1985) with a donut tire for my rebuild. Just enough to have a wheel to get on and off a rollback wrecker, or roll it out of the way. The P285/40R17 that will be used won't fit the C3 carrier.
Spike
Old Mar 3, 2006 | 10:22 AM
Ganey's Avatar
Ganey
The changeover to the small spare came w/ the major redesign in 78.
Old Mar 3, 2006 | 03:00 PM
IrishJoker's Avatar
IrishJoker
Along with larger fuel cells
Old Mar 3, 2006 | 07:01 PM
67-73-76's Avatar
67-73-76
Default Spare Tire
If using a doghnut for a spare make sure it fits the rear.
Some doghnuts will not fit the rear because of the e-brake cable mounting clip welded to the trailing arm.
To Spare tire carrier
