Engine noise
Old Mar 1, 2006 | 02:42 PM
ADub's Avatar
ADub
Default Engine noise
I am going to look at a 78 L82 4 spd tomorrow night. Owner used to drive it regularly, overheated it. He had the crank redressed, cylinders honed, reassembled it himself. One of the heads was cracked, so he had an older set rebuilt at a shop and he assembled the engine. He admittedly did not know what he was doing. He once he got it running again, the engine idled very rough, sounds "tight" and will squeek after warming up. He says he can't get it to idle correctly and blames it on the carb.
My guess is he probably over tightened the rockers or has the wrong pushrods in it. But what sort of damage could he have done to the bottom end and will an overtorqued bearing squeek?
Old Mar 1, 2006 | 02:51 PM
halfmoontrail's Avatar
halfmoontrail
My fear would be more basic, if he did not pre-lube bearings, or prime the oil pump, there could be squeaks and soon big problems.
Old Mar 1, 2006 | 02:59 PM
ADub's Avatar
ADub
Yea, I figured if I buy it, I have to expect that the engine is trashed and plan on tearing it apart before running it.
To Engine noise
