L88 with 2-Bolt Mains???
Old Mar 1, 2006 | 06:10 PM
TedH's Avatar
TedH
Default L88 with 2-Bolt Mains???
This really sounds like an oxymoron... BUT I noted that there is an L88 block (with pistons, rods and crank) with starting bid of $500 (reserve not yet met) with 2-BOLT mains on eBay:
http://cgi.ebay.com/ebaymotors/ws/eB...3ARTQ%3AUS%3A1
Now, when I think of an L88, I think brutal horse power and 2-bolt mains don't necessarily sound like an L88 foundation. This sounds more like the 390 or 400HP block; not the basis for an L71, L89 or L88...
Is this guy dreamin?
Info: Casting number: 3963512
This listed as either a 2-bolt OR 4-bolt block in '69 as a 427 or a 454 from 70-76 according to the following website:
http://www.mortec.com/bbc.htm
So, I suspect this is NOT an L88
3963512....427.......69......2 or 4 bolt
3963512....454.......70-76...2 or 4 bolt
NOTE: I inquired and the seller says '2-Bolt mains'...
Old Mar 1, 2006 | 06:21 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
So how do you distinguish a L88 block from other 427 ci blocks, maybe you don't or can't, I don't know ?
Old Mar 1, 2006 | 06:28 PM
dgruenke's Avatar
dgruenke
See this thread that I posted earlier.
L-88 on ebay
Old Mar 1, 2006 | 07:39 PM
GDaina's Avatar
GDaina
you don't L79/88/89 all used the same 4 bolt main block
Old Mar 1, 2006 | 07:58 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the perfix letters on the stamp pad
Old Mar 1, 2006 | 09:29 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
According to the prefix # this is a 1969 Pass Car 390 HP with 3 or 4 spd. IT IS NOT AN L88!!!! This guy is either doesn't know better or he is a thief!!!
Old Mar 1, 2006 | 09:35 PM
Dobermann's Avatar
Dobermann
Didn't the L-88 use the block of another engine, but had different heads. Would it be considered an L-88 without the heads?
Old Mar 1, 2006 | 11:36 PM
GDaina's Avatar
GDaina
As I said above, same 4 bolt main, 427 block was used in al hi-po motors. Only difference between L88 and L71/89 was the cam, rods, pistons, valve springs, pushrods, carb, intake, and round port exhaust aluminum heads.
Old Mar 1, 2006 | 11:40 PM
big_G's Avatar
big_G
Originally Posted by GDaina
As I said above, same 4 bolt main, 427 block was used in al hi-po motors. Only difference between L88 and L79/89 was the cam, rods, pistons, valve springs, pushrods, carb, intake, and round port exhaust aluminum heads.
You meant to say L-71.....?
Old Mar 1, 2006 | 11:43 PM
GDaina's Avatar
GDaina
Daaaaaaah....yes...
Made the correction...thanks
Old Mar 2, 2006 | 06:43 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
It looks like the seller did too.
Old Mar 3, 2006 | 12:37 AM
MotorHead's Avatar
MotorHead
I have seen 427ci blocks go for as high as 5 grand on Ebay it all depends on the date code? so the they can be transplanted in expensive collector Vettes
The last one I saw was similar to this block as it was from a mid sized passenger car and I emailed the the buyer ( his ebay name was 67Vette or something similar ) and he said he didn't care it had the correct stamping for him
To L88 with 2-Bolt Mains???
