How much adhesive ?
With all the adjusting and fitting to get a good fit, inserting screws to hold things in place, attaching splash shields and front support rods, checking straightness with rocker panels, the 5-8 minute set up time is too little for me.
I am sure there are people that work faster than I do, but the extra time is worth it to me.
To answer your question, get a gallon.
Just my 2 cents.
If you need longer cure time, I would recommend 3-M 8219. The applicator tip makes the fender-wells a breeze. Figure on 4 tubes.
after helping a friend install a fender, we bonded the headlight area
(iirc metal to glass) with a fusor product, really slow dry, almost thought it wouldn't harder
when it did it had a flexable feel. like silicone.
a few days later we did the rear of the fender with regular bonding adhesive
it cured to fast. door fit off by 1/8" (good as factory
) the front area stuck solid,would not attempt to break it loose, much stronger then we thought.
we ended up pulling the fender out 12-18" to grind and rebond.(fun)
so on the '74, after fitting the FEA I want to bond one side at a time with something slow
is 3m 8219 the only choice?
thx rod
and where to buy, I can't seem to find it online
I've had good luck with Fusor 127EZ by Lord Corporation. See www.fusor.com. The 127 states about 60 min open time. Also about $40 for 10oz tube, which can add up. Those special two plunger guns are required, but my paint store has always loaned me one to use.
Good luck.
Ralph.
http://products3.3m.com/catalog/us/e...er/output_html
