Rear End Whine
Old Mar 4, 2006 | 09:00 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Default Rear End Whine
My son and I took the vette out of storage and I took it on a number of errands today to diagnose the rear end whine. (At least that's what I told my wife.) The whine symptons:
- Whine sounds like it is coming from the right rear
- No whine at low speeds (<40)
- No whine on accel
- No whine on decel
- Only whines when traveling at a steady, highway speed.
I'm taking the car in for fluid changes on Tuesday. I was going to have them drain the diff and refill it with Royal Purple. Since the problem seems to be coming from the right side, could there be another cause?
Old Mar 4, 2006 | 09:03 PM
Retro78's Avatar
Retro78
The problem is your exhaust...put on Flowmasters. That will fix it for sure.
Old Mar 4, 2006 | 09:05 PM
Retro78's Avatar
Retro78
Seriously. It could be your diff, but I would also check wheel bearings and U joints.
Old Mar 5, 2006 | 02:23 AM
pcfred's Avatar
pcfred
St. Jude Donor '05
Royal Purple quieted mine down. Some say a little whine is common.
Old Mar 5, 2006 | 09:51 AM
80TexasC3's Avatar
80TexasC3
&amp;amp;quot;Rodstoration &amp;am p;quot; In Progres
I agree on there being a little whine... I just installed a new 3.72 and have the whine also... Like the flowmaster idea...or just turn up the radio.
Old Mar 5, 2006 | 10:12 AM
rihwoods's Avatar
rihwoods
Hard to say....check for play at rear wheels...could be tire,also...
Old Mar 5, 2006 | 07:04 PM
icanfixitforyou's Avatar
icanfixitforyou
Well, here's an excuse for another test drive. Is the whine more pronounced in a long sweeping turn? If you get the car to lean to one side or the other, does the noise change? If so it may indicate wheel bearings being the source of the noise. Good Luck!
Old Mar 6, 2006 | 10:25 AM
LONGFISH's Avatar
LONGFISH
I have the same symtoms.
Please let me know what you find.
I'll do the same.
Good Luck
Old Mar 6, 2006 | 02:52 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
Is anyone running Schaeffer's #267 gear lube and what are the results? The folks with quadrasteer trucks often use the stuff to get rid of gear whine.
http://www.schaefferoil.com/gear_oils/267.html
Old Mar 6, 2006 | 02:56 PM
rihwoods's Avatar
rihwoods
2 LBS of hambuger meat in the rear end will do it too...worked great on a Plymouth I traded in once...
Old Mar 8, 2006 | 08:55 PM
icanfixitforyou
I was told to put in sawdust, but never hamburger!
Old Mar 11, 2006 | 02:31 PM
lebvette's Avatar
lebvette
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21
If the noise is coming from the right or left and not the center....should be a wheel bearing. I've already replaced both mine by 70 thousand miles. These aren't a piece of cake to change, tho. Larry
Old Mar 11, 2006 | 03:25 PM
dgruenke's Avatar
dgruenke
What size tires are you running. Larger tires produce more tire noise. Are you sure it is coming from just one side. At higher speeds, this would be difficult to detect.
Old Mar 11, 2006 | 04:17 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
My mechanic says he can't find any cause for the whine. Per my request, he ordered some Schaeffers and we'll see if it does the job next week.
Old Mar 21, 2006 | 04:51 PM
LONGFISH's Avatar
LONGFISH
What is the word?
Old Mar 21, 2006 | 05:04 PM
carbster09's Avatar
carbster09
Default "New" Rearend and whine too?
I have the same problem. I had my rear rebuild with 3:55's as I hated the 3:08's, but now have more whine...?
Its not alot, but more than it had. Maybe Royal Purple would work? Any ideas?
carbster
Old Mar 21, 2006 | 06:08 PM
IMA 66's Avatar
IMA 66
mine started whining on the way back fromthe crab cruise last year. At first i thought it was coming from the front but now i am leaning towards the rear....sounds like bearings and when i make a right hand turn pretty hard it will go away....how hard is it changing the rear bearings????
To Rear End Whine
Old Mar 21, 2006 | 09:25 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I picked the car up from the mechanic today. (It took a week for them to get the Schaeffer's gear lube plus they were backed up.) He said that it still whines but they couldn't find any other problem. The diff had some small metal particles in the old oil, and is seeping a bit from the seals. He suggested that I put a few thousand miles on it this summer and see what happens to the whine. If it get worse, he can do a rebuild next winter. I've only driven the car a few miles and the whine seems less. I'll have to see what I hear over the next few weeks.
Old Mar 22, 2006 | 12:22 AM
C3Racing's Avatar
C3Racing
St. Jude Donor '07-'08
Sounds like a bit of pinion gear noise..?
Old Mar 22, 2006 | 12:05 PM
GTR1999's Avatar
GTR1999
chances are the gears are worn as are the yokes. Drive it and see. I doubt the oil will solve the problem. If you need advice tearing it down in the future let me know.
