Which Insulation is Best?
Old Mar 5, 2006 | 09:48 PM
icanfixitforyou's Avatar
icanfixitforyou
Default Which Insulation is Best?
I want to insulate the interior of my 79, mainly because of heat, but the noise levels are high also. I have seen mention of Dynomat, Duramat, Reflectix, Nuprene, etc... What works best?
Old Mar 5, 2006 | 10:26 PM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
Combonation of Reflectix layed down for a thermal barrier first and on top of that Nuprene for sound deadening. At 3/16" thick and very light weight and easy to work with it is a very tough combo to beat IMHO, houstonvett
Old Mar 5, 2006 | 10:33 PM
Mark G's Avatar
Mark G
Just curious what are the prime places around the interior you all have insulated. Do you remove the factory firewall insulation or go over it?
Mark G
Old Mar 6, 2006 | 01:11 PM
Tele_Man's Avatar
Tele_Man
I put down Dynamat first, then the Reflectix on top of the Dynamat.
I covered all of the fiberglass tub in the driver/passenger cockpit. I did not cover the top portion of the center console area. It would have required too much futzing with cables, wires, etc. I didn't think the effort would be worth it. I also covered the rear deck and sides of the wheel wells. I did not cover the interior of the battery compartment or the jack compartment.
To Which Insulation is Best?
