Help with power window
Old Mar 6, 2006 | 05:13 AM
Rob vette's Avatar
Rob vette
Default Help with power window
Hello corvette friends went to lower passenger side window and you guessed it no go I pulled the consuel to check if the switch was connected still hooked up so I swapped power window switch to each other still no go?it was working about 1 month ago so my next is to pull the door panel to check window motor? any tips as to check window motor would be help full . thank-you .
Old Mar 6, 2006 | 05:20 PM
jdp6000's Avatar
jdp6000
Wiggle the wires where they go through the door jam to the door.
When you hit the switch do the lights in the car dim?? If so It could be a broken regulator spring. The motor does not have enough strength to raise the window without the spring.
If all of the above prove negative. check the connecting to the motor.
Jim
Old Mar 6, 2006 | 10:29 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Bang on the door panel at the same time hold the switch. It may come up.
If you need to remove the door panel check the wires where they plug on the motor. The prongs on the motor get corroded and don't make good contact. Take a file and clean them put the plug back on and try it.
Old Mar 7, 2006 | 12:23 AM
c3 in hawaii's Avatar
c3 in hawaii
Did this on my '78, works fine now..
To Help with power window
