Welding Question
Old Mar 6, 2006 | 10:41 AM
1982CorvetteDude's Avatar
1982CorvetteDude
Default Welding Question
I'm getting ready to relocate my parking brake brackets on top of my trailing arms for more clearance against my wheels and had a question.
I have one of those $170 cambell-hausefield wire feed flux core welders from walmart. Other than "trash that welder" or "get a better one" is there any solid advice anyone can give me to be able to weld two tiny brackets? This is all I'll ever weld so i'm not going out and buying a bigger welder, and my car is immobile right now.
I'm by no means a experienced welder but I'm trying to practice with some scrap steel and I can get a good bead but it doesn't penetrate the bottom piece of steel. It's rock hard and unbreakable on the top piece though.
1. Is there a certain point to ground the metal?
2. Is there a spray that you can put on the metal to get better contact?
3. what dia wire do you reccemend?
or will I do better getting a stick welder to do this? If I can't get it I may just cut the old brackets off and when i get the car running take it to a welder and let them do it for me. After all it's just the parking brake.
Old Mar 6, 2006 | 10:52 AM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
you could try and get someone that does iron fencing that has a mobile welder on their truck to come by and weld them on for you. they should be able to do a better job if you're not that good of a welder. if you go at it yourself just make sure weld area is clean and grease free, paint that kind of stuff set welder with a good ground and set welder on the hot side and back it down as you go along if is too hot good luck
Old Mar 6, 2006 | 11:04 AM
greg454's Avatar
greg454
Thats a small welding job and your welder should be fine for it. Just keep practicing on some scrap untill you can get a decent looking weld. If your not penetrating the bottom piece of steel then you need to angle your rod down toward the bottom piece more. Your puddle should be covering both pieces.
Old Mar 6, 2006 | 11:06 AM
Blue 74's Avatar
Blue 74
Wire diameter is pretty much determined by the tip already on the welder and the diameter the welder is set up for. I think somewhere around .023 to .030 for smaller welders.
Ground as close as reasonably possible to where you are welding. Ground does not work well through rust.
No spray that I am aware of.
Practice on the same thickness of metal in the same configuration as what the real weld will be.
Old Mar 6, 2006 | 11:39 AM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
you should be fine, just practice...grind everything clean...and get a book on welding sometimes you grind a 45* angle on the pieces and sometimes you seperate the pieces to get the penetration....depends on the angles involved...and its ok to tack it in place and come back to it....all flux must be removed prior to rewelding
Old Mar 6, 2006 | 11:50 AM
NHvette's Avatar
NHvette
Getting the pieces/area down to clean metal before welding is most important.
You should do fine after some practice on scrap.
Old Mar 6, 2006 | 11:58 AM
Gordonm's Avatar
Gordonm
I'm in the same boat but have no welder at all. I need to find someone with a welder to do this small job for me. Sometimes I wish I had a small mig but just can't justify the cost for a once a year usage.
Old Mar 6, 2006 | 12:14 PM
djgrelli's Avatar
djgrelli
Practice makes perfect is the old saying. I have a Lincoln Weld Pac 100 and have welded sheet metal to the engine mounts in my son's Jeep. Sounds like your not getting penetration. Turn down the wire feed speed and stay in the puddle as long as you can.
Old Mar 6, 2006 | 01:16 PM
The_Dude's Avatar
The_Dude
St. Jude Donor '11, '16-'17
Are you trying to weld through the top piece into the bottom peice? You should be welding the edge of the top piece to the bottom piece. Point your arc more at the bottom piece, and melt the edge of the top piece.
Old Mar 6, 2006 | 02:07 PM
Twin_Turbo's Avatar
Twin_Turbo
.30 wire will weld about anything you could ever need on these cars, there's no real thin sheet metal that you need a smaller wire for and nothing thicker that requires a thicker wire. Practise makes perfect but a good machine and gas also helps, just like infinite wire speed control, trigger contact (instead of always hot)..and so on...but practise is most important. Oh and like others have said above..clean clean clean. You want the metal to be clean enough to eat from. Train your eye to see the root when welding and especially the darker outer edges of the weld pool to see if you have penetration all the way (kinda hard since the glowing white center makes it hard to focus on the other parts...but you have to practise that), always keep feeding into the leading edge so you get penetration and not fusion and just a lot of material buildup.
Here's how clean the metal should be:
notice the absolute lack of spatter, that's what gas will do for you (and the proper gas and machine settings), no anti spatter spray or anything was used (I never use that kind of stuff)
Old Mar 6, 2006 | 02:17 PM
big_G's Avatar
big_G
Gordonm....let me tell you something....once you have a mig welder, you will be looking for things to weld.... Besides, when you get good you can fix anything steel..garden tools, steel furniture, and charge your neighbors to when they come running, to help pay for the welder...
Old Mar 6, 2006 | 02:22 PM
Twin_Turbo's Avatar
Twin_Turbo
so true... so true
Old Mar 6, 2006 | 02:41 PM
SharkAttack's Avatar
SharkAttack
Agreed - I borrowed my brother-in-law's welder to make a fence. Now I'm shopping for a welder...
Old Mar 6, 2006 | 02:55 PM
Gordonm's Avatar
Gordonm
I can probably get a very good deal on a welder also. Some of the distributers for our products are welding supply houses. Might start shopping around. I actually am giving a seminar on our products at an Airgas store tomorrow. Maybe I'll take my trailing arms and see if they can give me a demo.
Old Mar 6, 2006 | 02:57 PM
big_G's Avatar
big_G
That's who I use...1/4 mile from my shop...
Old Mar 6, 2006 | 06:36 PM
bobs77vet's Avatar
bobs77vet
can you bring them out to the shore?
Old Mar 6, 2006 | 07:09 PM
Gordonm's Avatar
Gordonm
OH Yea! No problem. I assume you have a welder? If so let me know when and where.
To Welding Question
