pulling motor and trans....
just a few questions
do i have to pull the radiator?
is there a trans mount or just 2 motor mounts?
any other items i need to look out for that i need to take off that isn't attached to the motor?
hopefully i'll order up my items and find a cherry picker to pull the motor.... i really don't want to buy one....
b
is there a trans mount or just 2 motor mounts? theres both
any other items i need to look out for that i need to take off that isn't attached to the motor? yer driveshaft would help
hopefully i'll order up my items and find a cherry picker to pull the motor.... i really don't want to buy one.... i'm thinking u could borrow Roy's(the quick 1)
I removed my engine first and then removed my transmission second. I wasn't planning on removing my transmission at first, but once the engine was out, I figured that I might as well work on the transmission. So I can't give any advice on removing them together.
The engine weighs around 600 pounds (for an L-48 with no aluminum). I would estimate that a TH350 transmission weighs around 80-120 pounds (drained and without the torque converter). I can pick it up on my own so I know it doesn't weigh more than that.
Yes, there are two engine mounts and one transmission mount (on the crossmember).
Comming from a complete novice, removing the engine and transmission isn't that hard to do, just a little tedious. Be sure to mark everything and take lots of photos as to how things looked when they were together.
Also plan for a mess and lots of fluid spills.
thanks
b
