Testing New Heater Core ?
Old Mar 11, 2006 | 05:51 PM
79vetter's Avatar
79vetter
Default Testing New Heater Core ?
I picked up the new Heater Core today and just want some assurance that it will hold . I have read some posts about sending air through one side and plugging the other to check for leaks. I don't have an air compressor to work with . Anyone got pics demonstrating a leak test ?
Old Mar 11, 2006 | 06:02 PM
blitz10's Avatar
blitz10
I had a shop replace my evap core and change out the heater core while in there. I supplied the parts. From reading on the forum, you do want to be sure that there are no leaks. My new parts were taken somewhere, radiator shop??, and nitrogen tested to be sure that they were good. I have read the horror stories that when all done replacing partsand still having a leak. I quess it's possible to have a new core and still have a leak.
Old Mar 11, 2006 | 11:29 PM
blbeck's Avatar
blbeck
I had a new heater core that leaked, but I tested it by blowing into one end and putting my thumb over the other opening I could hear the air escaping from where the hole was.
Bob beck
Old Mar 12, 2006 | 12:12 AM
yukon988's Avatar
yukon988
I've done the same as blbeck. I've also taken them to a radiator shop. They do this all the time. They will pressurize it and stick it in a tank to see if you can see any bubbles.
Old Mar 14, 2006 | 11:06 AM
79vetter's Avatar
79vetter
I will be taking it to a radiator shop later on today. What about A/C Evaporators? I bought a new one and want to leak test it as well. Do you just run air through it?
Old Mar 14, 2006 | 11:22 AM
kdf1986's Avatar
kdf1986
I read about testing the heater core with a bicyle inner tube.
Cut the tube in half and install on the ends of the heater core. Use hose clamps or tie wraps to seal this off.
Inflate the tube with the air valve. This will pressurize the system. You can then either hold it under water in a bucket large enough to fit to look for leaks, or you can wait and see if the air escapes.
I prefer the bucket method. If the air is escaping from the hose connections, then you know why it is leaking. You want to see if it is leaking from the core. That is why the pressure test under water should work.
kdf
Old Mar 14, 2006 | 12:32 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
kdf
Old Mar 14, 2006 | 12:40 PM
Wuttin's Avatar
Wuttin
not quite as sophisticated as the inner tube, but someone suggested strapping a garden hose to the inlet and running water through to check for any leaks.
To Testing New Heater Core ?
