well, here we go!
The interior is shot completely. I have already begun ordering carpet, etc. The dash is bent and warped badly. No resurrection there. The paint is pretty good and will not need attention for a few years. The wheels and tires are very good. All the glass and the windshield frame is fine. Under the hood looks good too. The rear window is torn so I guess that means a new top.
The standard 350 (I assume) misses terribly and stumbles on acceleration. My daily driver van could beat it 0-60. She really does not like it above 70 mph (4 speed). When you let up on the gas it backfires A LOT. Also, about half way home she started cutting out sporadically. We thought we were going to have to walk the last hundred miles. I don't think it even got 10 mpg. It has some model of edelbrock carb. The motor sounds OK. (I am NO mechanic). There are no wipers working and no heat. We got the fan to blow up through the defrost. I don't even know where the wipers come out! (dumb C4 guy). The console control units for the heater A/C and wipers seem to be broken.
This year I will concentrate on the interior. I absolutely will welcome any and all advice. When it comes to C3 knowledge I have no pride. I LOVE THIS CAR! It rides like a lumber truck compared to my 91 and it's not nearly as fast but THAT LOOK! Nothing like a red C3 vert!
It sounds like you need some work on the vacuum system and just about everything else in the engine compartment. You will progress from " I am NOT a mechanic" to "My mechanic doesn't know Sh*t" before you are through. Good luck and dust off your checkbook.
Rick B.
I figure this to be about a five year project... I do not have the level of commitment that lots of you fellows have nor do I have any "corvette guys" around to assist. I do have access to a good GM-trained independent mechanic who tries not to laugh too much when I bring him my stuff I have messed up. But this car is not about having pros do the work. I will do 100 percent of the work I am capable of doing, as I did on my 91.
I read this section every day. That is how much respect and admiration I have for this group......
Good luck. No better feeling then improving a car with your own 2 hands.
trw
Very true! You can see mine if you click on "My Corvette Photos". Welcome to the wonderful world of C3s. I would change spark plugs, cap, rotor, points, condenser, and wires. Good old fashioned tune-up. Lose the Edelbrock carb and get a Quadrajet rebuilt by Lars. That base 350 should run like a scalded dog.
Do a forum search for wiper/vacuum problems. The systems are not rocket science to troubleshoot. Ask lots of questions- there are plenty of knowledgeable C3 guys here.
Rich
Cool welcoome to the world of C3's and chrome to boot. First of all i want to commned your bravery for making that trip. second of all the fact that you got it home at all is a reaaly good sign, means the old boy still has heart
Some one said get the assembly manual ans service manual. I would add picking up a copy how to restore and modify your corvette http://www.amazon.com/gp/product/076...lance&n=283155
I got this before i bougth my 68 as a guide of what to look for, it is a very handy book.
thne i would do the following
get it up on a lift or stands, and closely examine the front and rear suspension, and brakes. and fix anything you find. then do a general tune up replacing al the fluids, filters, and plugs, points, cap and rotor. This way at least you know you can drive it saefly with no surprises.
Then deice if you will do a rolling resto ( still get to have fun while working) or the frame off type, then decide on modifications enhancements
again
suspeinsion - busings, springs, shocks, control arms, ball joints tie rods etc.
Brakes - calipoers, lines hard and rubber, MC, (booster if poweer)
Powertrain - Top end fresh up carb, intake, ignition, cam or Complte rebuild to include pistons, rings, bearings, rods, crank.
Tranny and diff
just some thoughts
Congrats and ggod luck
tim
The heater controls on my 68 were all cable driven, not sure when they switched to vaccum
One suggestion I have (and I may get flamed for it) is to consider what and how much documentation you have for your car. If it came with a good history of who owned it, etc, and it hasn't been overly modified, you MIGHT want to consider keeping it stock, for long-term value and originality. Or that might not be your style, that's fine. I found with mine, that it had a lot of good records and is about 98% stock, so I decided to keep it that way - I love this car and mine's not about being the fastest. Good luck and let's see some pics.
Mark
http://www.1970stingray.com
again
tim
Also go to
Doc Rebuild and pick up his vac system trouble shooting guide. That and a vacuum gauge will tell you what parts need to be replaced to get your headlights and wipers working.
Sounds like you might also need to look at getting the carb looked at/ replaced.
Scott
p.s. Enjoy!!
Yep, I DO want to see some other chromies if in the area.
Oh and by the way, I let junior drive her home most of the way. He never offered the wheel back to me........
