Putting in carpet Issues!!
Old Mar 13, 2006 | 10:21 AM
mpett1's Avatar
mpett1
Default Putting in carpet Issues!!
Guys how in the hell do you put back in those black rubber carpet holders up in the back of the cargo compartment? I already ripped 2 of them..
Old Mar 13, 2006 | 10:55 AM
Muddywaters's Avatar
Muddywaters
Old Mar 13, 2006 | 11:14 AM
jlsru's Avatar
jlsru
Cruise-In V Veteran
I didn't even try to install those.I used velcro.
Old Mar 13, 2006 | 03:57 PM
mpett1's Avatar
mpett1
Ok thats one thought
Old Mar 13, 2006 | 04:04 PM
Greg's Avatar
Greg
Just another Corvette guy
mpett1,
I've put in many carpet sets and I never re-use those rubber plugs 'cause they'll drive you crazy and probably tear anyway. I usually spray the carpet and rear wall with contact cement, wait ten minutes and Bingo!......problem solved.
Good luck,
Greg
Old Mar 13, 2006 | 04:05 PM
troy1m's Avatar
troy1m
I just had to pull mine out yesterday and i don't think they're to be reused, i glued a small wooden block over the hole and used a quarter sized washer and small screws. works good and is removable
Old Mar 14, 2006 | 08:25 AM
mpett1's Avatar
mpett1
Thanks guys. I think what I am going to do since I already put the holes in the carpet for them is to cut the back of the rubber fitting of and just glue it into place where it should go so it looks correct and then just glue the rest of the carpet to the back wall.
Old Mar 14, 2006 | 12:46 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Parts stores have all sorts of retainers. I found some black plastic ones with a "toothed" shaft. The teeth are angled so they slide in easily, but don't come back out. It's not too hard to break them if you need to remove the carpet.
Old Mar 14, 2006 | 02:29 PM
myoriginal77's Avatar
myoriginal77
Some of those plugs seal up the alignment holes in the body. If the plug has a hole in the middle a small punch will fit and it streches them slightly to poke through. Also a little silicone or liquid soap helps.
Frank
Old Mar 14, 2006 | 02:32 PM
mpett1's Avatar
mpett1
Frank
Yes I tryed WD-40 and the punch blew right through..
Old Mar 14, 2006 | 03:25 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I did the same thing with a Phillips screwdriver.
Old Mar 14, 2006 | 04:28 PM
NHvette's Avatar
NHvette
Both fairly pointy instruments.
... soapy solution and a blunt rounded tool to push 'em in.
(I'm not using them ... probably use 3M spray adhesive)
Old Mar 14, 2006 | 05:15 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Lube them well, and push them in GENTLY using a phillips head or a punch.
After you get them started, reach under the car and grab the end with a needle nose plier of some such device and pull them through the rest of the way.
Do the same for the front carpet plugs. Chuck
Old Mar 19, 2006 | 12:48 AM
NorthShore Bob's Avatar
NorthShore Bob
Never, ever use a screw driver or punch on the rubber plugs. They used a special tool to install them, and you can make one yourself for a a couple dollars. Get a piece of threaded #8 or #10 rod,(or a long screw) Bend the threaded rod about 4 inches from the end, forming an L shape. Get a an oversized fender washer and a nut. Run the nut up an inch or so, put the washer on, and insert it in the plug. Adjust the nut to allow the rod to push on the inside and stretch the plug. the washer controls how much stretch is applied, with out letting you pierce the plug end. It also facillitates installing the plug, along with a little grease, vaseline, or oil.
Another thing. WD-40 is not a lubricant, it is a solvent! Get your hands really dirty grimey greasy sometime, then spray a little WD-40 on and it will cut the grease and you'll be cleaner faster than if you used anything else.
Try it sometime.
Old Mar 19, 2006 | 01:12 AM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
WD40 is a solvent AND lubricant. I'm so sick of that rumor...
Old Mar 19, 2006 | 01:15 AM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Better solvent than lubricant though.
Old Mar 19, 2006 | 08:02 PM
Flying Ace's Avatar
Flying Ace
St. Jude Donor '05-'06
Carpet holders?? Are these in an '81??
I'm putting new carpet in this week and I can't figure out what you guys are referring to.
To Putting in carpet Issues!!
