Where do I find engine I.d./VIN?
Old Mar 13, 2006 | 02:28 PM
1985 4Runner's Avatar
1985 4Runner
6th Gear
Default Where do I find engine I.d./VIN?
I have a Corvette engine in my truck, but don't know the history as I purchased it used. Where can I locate the VIN/engine I.D.? I would like to know what year/type Corvette the engine came out of, as well as other specs. Also best type of oil to use, filters, plugs..etc. Any help out there would be greatly appreciated.
Old Mar 13, 2006 | 04:11 PM
LittleJake's Avatar
LittleJake
The front of the passenger side head there should be a lip on the block with numbers stamped into it. There will be a row of numbers and then a three digit letter suffix to indicate what type of motor it is. The row of numbers relate to the vin in the car. Look for the three letters and post or search the internet to find out what it came from. If you get the three digits I will look it up on my list and let you know.
Good luck.
Old Mar 13, 2006 | 08:05 PM
1985 4Runner
6th Gear
Thanks!
I found the plate as instructed, but I didn't see the three digit suffix. The imprit on the plate was: 16S431706 V0414CKX. (third letter is not the #5)
I don't know if this helps, but thanks again for everything.
Old Mar 13, 2006 | 08:11 PM
RobRace10's Avatar
RobRace10
I think it's a 76 the 1st number is probably actually the letter L
the CkX would be a 350ci 180 HP with an auto trans
Old Mar 13, 2006 | 08:37 PM
LittleJake's Avatar
LittleJake
Old Mar 16, 2006 | 10:51 PM
1985 4Runner
6th Gear
Thanks! I can now search the threads here for more info on specs, filters, oil, etc...
Thanks again!
To Where do I find engine I.d./VIN?
