Body On Frame Refinishing
How would you guys recommend refinishing the frame and accessible components with the frame on. I realize removing the body is the way to go. Looking for ideas,pictures of body on would provide inspiration.
Rick B.
Disconnect: Wires to alt, ac, dist, fuel gauge/sending unit basically any wire that will stay with the body, vacuum lines, carb linkage, e-brake cable, trans cable, fuel lines to pump, brake lines at master cyl., trans. cooling lines at radiator, steering linkage, remove radiator and fan, body mount bolts, bolt up front that hold the frame extension(it will stay with the body). If applicable, remove as compressor from the engine and let it go with the body so you don't have to recharge the system. After you unhook all the other things I forgot to list, get 6 buddies or one hoist and lift it.
Thats all I can remember right off, maybe someone else will add to this.
I also painted the engine without removing it.
I did not remove the body or even lift it. I used Por15 and top coated with rustoleum satin black. I removed the brake and fuel line mounting clips to paint underneath the lines. I also painted the brake and fuel lines it was easier that way. However, as you can see I don't give a rats a$$ about factory correct.
Trust me - I am very fond of the product.
However, I think I would just hit it with some rattle can
paint if thinking about taking the body off in the future.
If you think the body will stay down for a long time - then
take the time to do POR or similar. It is a LOT of prep to
"do it right". If simply washing and painting - go with enamel.
I prefer Krylon semi-flat black (usually over silver POR15).
Good Luck
http://nhvette.homeunix.com/ftp/in/frame_paint_02.jpg
http://nhvette.homeunix.com/ftp/in/frame_paint_04.jpg
http://nhvette.homeunix.com/ftp/in/chassis_02.jpg
i also did a frame on. i'm an advocate of por-15 also, great stuff, used it on my shell, frame, and all suspension parts then top coated. i've been using por-15 since it 1st arrived on the scene back in the early 90's, wish'd i'd a bought stock in it! i also used Krylon semi-flat black for topcoat on the frame, don't like shiny frames.
the only way
