My 72 currently has the normal power steering ratio set on the knuckle, i.e. the outer tie rod is located in the forward hole of the knuckle.
Did anyone ever change to the rearward hole (which is normally used on manual steering cars) with power steering.
I would think that the steering might improve because it is a bit less direct. However it could be too easy to move the steering wheel due to the added leverage....
Any experiences/opinions would be highly appreciated.
If you have a car with manual steering (as I do) would changing it to the normal (slower) ratio make steering effort a little easier? My cars previous owner set the car up with the fast ratio even though it is manual steering. Wondering if chaning it back would make my life a little easier.
