Hey Karl, First off, let me thank you for serving, I'm guesssing you are in the military and secondly the major and in my opinion the only reason not to buy any corvette would be for frame rot/rust along with "birdcage" rust/rot,,, anything else can be dealt with more easily, Good luck over there and good luck in your future buying the car of your dreams,,,Peace,,, Moosie
The list can get long depending on what you can live with. To me the worst things are "surprises" and there are usually a few with each car I have worked on. Bubba can get you without you even knowing it. If the car has not been kept up to daily driving standards you should expect to replace wheel bearings, u-joints, all rubber bushing and pads on the suspension. Then there are the leaky things like hoses, seals in the engine, trans, power steering system, brakes and differential. These seals become especially leak prone if the car has sat for six months or more. I mention rustrot last because it is usually easy to spot. Surface rust is easy to deal with, rot on the other hand requires more work and $$$. That brings us to plastic pieces. When I first started with the vettes I thought I could drive one that looked good outside but need work on the interior. Well, after buying an 80 with no interior and installing what the seller had to go with the car I have upgraded my standards. Cheap plastic 25 years old is fragile and expensive to replace. Now that I have you shaking; Good luck with it.
First order of business would be replacement of all fluids/filters and inspection of key wear items (belts, hoses, suspension bushings, brakes, bearings, shocks, tires, etc.) and a good tune up.
Also, if original, the vacuum systems WILL require attention. Often, leaking vacuum systems can cause mis-diagnosis of engine performance problems (rough/poor idle, poor throttle response). I replaced ALL vacuum system components from 1998-2000 on my L48. All vacuum components sourced from Dr Rebuild (www.docrebuild.com).
I'm over in Iraq right now. I found a 1980 Vette in good shape, on-line.
I'm sending my brother to drive it home.
This will be my 1st Corvette. I grew up on GTO's & Trans Am's.
What should a new owner of a 1980 model look for, mechanically, in this vehicle?
Thank you all!
Karl...
You have already accomplished the first and best thing....You joined the Forum.....Welcome and congrats on your purchase. Next is enjoy your ride, make it yours. You will get hundreds of ideas and opinions here as well as excellent advice and detailed help from radiator cap to gas cap. Already posted ahead of me are some very good starter ideas. So far I have had no mechanical defects, I just keep her washed and tuned up for cruising. Along with some local cruising we've done a few 500-600 trips without difficulty. Bank balance is teasing me to do some HP upgrades though.
