if it's a stud, u can just use 2 nuts and thread them on and tighten them to each other and then use the nut between the first nut and the block for the unloosing..........
Can you get vise grips on the stud? If so, heat the manifold as hot as you can get it with a propane torch ( plumbers torch). Then put on the vise grips and try to turn it out.
If it's broken close to flush, remove the exhaust manifold. Grind the old stud flat. Center punch the stud as close to center as you can. The thread is 3/8-16 NC which uses a 5/16" (.3125) pilot drill.
Hold the exhaust manifold in a vise or other secure method. Start with a smaller drill ( 1/4) and drill thru the stud. ( make sure you are drilling square to the surface so you don't make an out of round hole )Work your way up to 5/16 if the stud doesn't come out. Clean all the threads with the tap.
If you have a little sticking out you can weld a bolt to it and use a wrench. Try some heat from an oxy/acetylene torch around the stud if it doesn't come easily.
I used a stud extractor and heat and it still snapped, it is flush with the manifold now. I went through this with a manifold last year (must be me!!) and took 3 days of drilling to remove (bad drills?!?!?!). I have contacted a shop that extracts them somehow so I don't have to fool with the other 2 also. Here is a link to them, just wondering if anybody ever used this method. http://www.brokentap.com/services.html http://www.Cammann.com/
Jeff
I will also add, left hand twist drills are best for this. If they grab, they are turning in the correct direction. also alternating heating and penetrating oil may help.
