coat gas tank
Old Mar 19, 2006 | 07:37 PM
kessler's Avatar
kessler
Default coat gas tank
just bought new gas tank and was wondering if I should coat the outside??? Should I spray a clear coat on it to prevent rust or is it ok left alone??? Thanks
Old Mar 19, 2006 | 07:44 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
My 0.2, just leave it.
Old Mar 19, 2006 | 07:49 PM
carl a's Avatar
carl a
mine was painted black(whithout my go ahead) during my restoration,,and i repainted it silver, to look like a gas tank!!it was a year old and rust started at the seams,,so i wanted to protect it ,,,por-15 has paint called metal mask that looks like bare metal but isnt,,,my tie rods are coated with the stuff,, within 2,000 a car that has had a body off restoration will have surface rust starting,,,my way of thinking was (even thou it was expensive) im doing this and wont ever have to do it again,, anything that i wanted to look like metal was coated with the metal mask and a top coat of glisten p c which is a rock hard clear coat
Old Mar 19, 2006 | 07:56 PM
JoeRags's Avatar
JoeRags
left mine alone too...
To coat gas tank
