MSD 6AL Ignition
Old Mar 20, 2006 | 01:37 PM
whitesnake81's Avatar
whitesnake81
Default MSD 6AL Ignition
Please show me pictures of where you put your 6 Al Ignition . I am having a hard time finding a good location.
Thanks!!
Old Mar 20, 2006 | 02:06 PM
JoeRags's Avatar
JoeRags
I put mine on the back side of the passenger fender well. Plenty of room back there, out of heat's way, and you can just run a power wire to the starter. sorry i dont have pics.
Old Mar 20, 2006 | 02:28 PM
Z-man's Avatar
Z-man
That's where I put mine also...
Old Mar 20, 2006 | 02:34 PM
Corey_68's Avatar
Corey_68
Have mine INSIDE the car on the passenger side under the dash. Away from the heat,moisture, yet easily available.
Old Mar 20, 2006 | 07:10 PM
carl a's Avatar
carl a
i talked to msd when my first box went out(from coil mounted on intake at a angle,,a air bubble forms and burns out coil,,and box,,need a dry coil not oil filled if using intake mount) they said that they have been doing tests that showed that the boxes actually worked better when mounted in engine compartment because of the heat,,the thing likes it hot!!-heres wher i put mine drivers side inner fender(look behind master cylinder)------------------------------------------------------------.
Old Mar 20, 2006 | 07:16 PM
JoeRags's Avatar
JoeRags
Having the box inside the car is good spot, nice and safe, but I wouldnt put it there. The 6AL, if I remember correclty, provides about 400-425 volts to the coil. With voltages this high, you will have a much greater voltage drop over a long length of wire. Its good to keep the box as close to the coil as possible to eliminate as much of that voltage drop as possible. Up under the dash is probably close enough... just dont put it behind the seats.
Old Mar 20, 2006 | 10:17 PM
MIKER's Avatar
MIKER
I mounted my Crane ignition box inside of the console, below the radio.
To MSD 6AL Ignition
