courtesy light
Old Mar 22, 2006 | 11:25 AM
cab's Avatar
cab
Default courtesy light
the courtesy light when i open the drivers door is not functioning. is it on a seperate fuse from the passenger door. pass. door works fine so it must be the switch. i took the kick panel off and wires seem to be fine. as usually your advice is appreciated.
Old Mar 22, 2006 | 11:44 AM
kona's Avatar
kona
Not trying to be a smart a$$ but is the bulb good. If so I think a new switch might be in order.
Kona
Old Mar 22, 2006 | 11:50 AM
cab's Avatar
cab
yes bulb works because when pass. door is open it comes on.
Old Mar 22, 2006 | 11:55 AM
corvetteload's Avatar
corvetteload
You don't say what year, but assuming they are all the same to my 69, one place to look is see if some corrosion on threads of switch and housing on car preventing a good ground Or maybe they have their own ground wire?!?!?!?). When you have the switch out, check the tabs on the wires that contact the switch, they are replaceable if broken. If all that passes, try a new switch after touching the 2 wires together to check the circuit....B
Old Mar 22, 2006 | 12:29 PM
cab's Avatar
cab
its a 77 thanks i will look at that. never ending what fun.
Old Mar 22, 2006 | 03:48 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
Sounds like the switch is messed up.
To courtesy light
