Hurst Shifter or Factory?
Old Mar 22, 2006 | 02:40 PM
Jerry Curl's Avatar
Jerry Curl
Default Hurst Shifter or Factory?
When I bought my Vette, it already had a Hurst shifter in it. But part of me feels like I want the car to look more factory.
What do you guys think, replace it with a factory shifter or keep the Hurst?
Old Mar 22, 2006 | 02:43 PM
C3 RV's Avatar
C3 RV
St. Jude Donor '15
I tend to agree with you - factory.
Old Mar 22, 2006 | 02:44 PM
crazywelder's Avatar
crazywelder
If it works good, get the factory look a like handle from one of the Vette supply houses for about $90. It has the round shaft and fake "t"
handle and it replaces the Hurst shift lever.
Old Mar 22, 2006 | 02:53 PM
Jerry Curl's Avatar
Jerry Curl
Hmmmm... Didnt know they make a look-alike shifter...
Old Mar 22, 2006 | 03:04 PM
crazywelder
No sense in changing the entire shifter if there isn't any problem with it.
This would only require dismantling the console.
Old Mar 22, 2006 | 03:54 PM
Jerry Curl's Avatar
Jerry Curl
Hey, that looks pretty good. Might just do that.
Im assuming the "T" is just for show, correct?
Old Mar 22, 2006 | 03:59 PM
Maine Vette's Avatar
Maine Vette
I've been wondering about this for a while too... How much of an improvement do the aftermarket shifters provide?
Old Mar 22, 2006 | 04:16 PM
crazywelder
That's the only picture I could find. All you would be buying is the new new shift lever down to where it attaches to the shifter with 2 bolts. The entire shifter remains intact. The "t" handle is for looks.
Old Mar 22, 2006 | 04:35 PM
jimmygmartin's Avatar
jimmygmartin
I got Hursts shortest handle for my shifter and put a slight bend in itto clear the console. Compared to the Corvette comp plus shifter it looks and feels really cool !! I just wish I could find a chrome ball for it.
Old Mar 22, 2006 | 04:40 PM
Jerry Curl's Avatar
Jerry Curl
Anyone know if the length of this look-alike shifter is comparable to the factory shifter?
And how much of a pain will this be to replace?
Here is the one Im considering:
http://www.madvet.com/shop?frame=1.1178
Old Mar 22, 2006 | 05:56 PM
Jerry Curl's Avatar
Jerry Curl
Ive seen the replica handle available with a black **** as well as chrome. Anyone know which color was standard on a '76?
Old Mar 22, 2006 | 06:17 PM
694speed350's Avatar
694speed350
Got a hurst on my 69 works great and doubt i would install back to original. however i might be interested in the replacement handel that looks original. if its just 2 bolts.
Old Mar 22, 2006 | 06:23 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
My dad has this in his c2.
Old Mar 22, 2006 | 06:24 PM
Jerry Curl's Avatar
Jerry Curl
Looks good. I just want to make sure I get the right version. Black **** or chrome. I like the chrome though...
Old Mar 22, 2006 | 07:21 PM
glen242's Avatar
glen242
Not hard to replace the handle through the console. Stock '76 was the black chrome ball. A new ball came with the new look alike handle. It's the least they could do after ripping you off, $90 +/-, for a shifter handle. Yes, I paid it because I wanted the stock look inside and would never give up my Hurst.
Old Mar 22, 2006 | 07:37 PM
Jerry Curl's Avatar
Jerry Curl
What is the advantage of the Hurst vs. the GM shifter?
Old Mar 22, 2006 | 08:38 PM
Jims79's Avatar
Jims79
Looks good. I just want to make sure I get the right version. Black **** or chrome. I like the chrome though...[/QUOTE]
The Chrome **** is the stock OEM from the factory for your year. Glad your keeping the hurst you will get better shifts & w/the factory shifter it will look cool.
To Hurst Shifter or Factory?
Old Mar 23, 2006 | 12:58 AM
IMA 66's Avatar
IMA 66
hurst shifts much nicer then stock. Mine had Hurst shifter with t handle when i got it and i replaced with the black **** replica t. I had to bend my shifter handle a bit as it did not line up good when i got it but after that it was easy ro install.
Old Mar 23, 2006 | 02:28 AM
comp's Avatar
comp
looks good
Old Mar 23, 2006 | 05:28 AM
Jerry Curl's Avatar
Jerry Curl
OK, one person said I should get the black ****, and someone else said the chrome. Anyone positive what belongs on a 76?
