my custom hood
Old Mar 23, 2006 | 08:24 PM
my72vette454's Avatar
my72vette454
Default my custom hood
When I did the twin turbo thing on the vette I needed to change hoods. I looked at a daytona hood and decided it would work good because it has a raised center section that goes all the way to the front of the hood (room for intake piping) and I liked the side vent holes thinking that they would help get rid of some underhood heat. With the carb hat on it wasnt high enough to clear so I had to cut the center loose and raise it. I cut it almost clear to the front and tapered it up and had to add 1 inch to the height of it to clear the hat. Anyways here are some pics of it. I had an L-88 hood on before and thats still my favorite hood but this one is growing on me.
Old Mar 23, 2006 | 08:34 PM
gdh's Avatar
gdh
great job, looks menacing.
Old Mar 23, 2006 | 11:09 PM
JonnHeather's Avatar
JonnHeather
Old Mar 24, 2006 | 01:37 AM
VETTEVIC's Avatar
VETTEVIC
Great job!
Old Mar 24, 2006 | 01:43 AM
rihwoods's Avatar
rihwoods
What I like is the functional aspect of the vents...to often,you see front facing scoops...in your case,the air travels thru front of vette,and escapes thru those vents...which means you are not building up pressure under the hood at the firewall...
Old Mar 24, 2006 | 09:12 AM
ruby76's Avatar
ruby76
From: Fairview Heights Illinois, near Saint Louis MO, STL C3 Shark
Can't make out the picture in your avatar, do you have any others to post of theengine bay? Looks wicked.
Old Mar 24, 2006 | 06:41 PM
Corv3tt3's Avatar
Corv3tt3
I like it.
Old Mar 25, 2006 | 03:08 PM
my72vette454
funny you should mention wicked...Here are a few more underhood pics and one of the guage panel I made. Keep in mind that this is still an ongoing project with lots of stuff that needs finished and or redone.
Mike
Old Mar 25, 2006 | 03:44 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Very nice hood
Old Mar 27, 2006 | 08:43 AM
ruby76's Avatar
ruby76
Wow, thanks for posting!
Old Mar 27, 2006 | 10:06 AM
Bangkok Dean's Avatar
Bangkok Dean
Old Mar 27, 2006 | 04:25 PM
stingraymaniac's Avatar
stingraymaniac
have you dynoed that beast? must be pretty much hp in that thing
Old Mar 27, 2006 | 08:02 PM
my72vette454
I might get there sometime this spring, I was headed to the dyno last fall but blew the trans up two days before. Our local vette club might do a dyno day in may so I am kinda waiting for that to happen.
Old Mar 27, 2006 | 08:10 PM
Guru_4_hire
Cruise-In V Veteran
where did you get those filters again?
I havent found a more elegant solution for my little project
Old Mar 28, 2006 | 12:01 AM
my72vette454
I ended up using flat panel filters that fit an 01 f-150 ford pickup, they were the largest size I could fit in the space I had. A friend built the boxes for me, he works in a sheet metal shop that builds alot of potato equipment and he very good with stainless steel. It took several cardboard models to get the fit right. I have ducting in the hood that seals them from the engine and they draw fresh air from the cowl area. I got in a little rain storm one time and it was funny to see how the rain in the center area of the windshield would run downhill and on the sides it ran uphill.
Old Mar 28, 2006 | 02:01 AM
comp's Avatar
comp
Mike
now i say
Old Mar 28, 2006 | 07:04 AM
Guru_4_hire
Cruise-In V Veteran
Good deal. I guess I am also going to have to make an elegant solution like that.
Old Mar 28, 2006 | 12:23 PM
my72vette454
I tried using round filters but couldnt come with anything that had enough cfm flow and still fit then I tried my old 14 inch k&n, wondered if I could make it oval shaped and use 1 on each side but that didnt work either. Now I can go to checkers or somplace and tell them I need a ford filter for my vette....that outta confuse the guy behind the counter.
Old Mar 28, 2006 | 04:31 PM
Guru_4_hire
Cruise-In V Veteran
I will think of something
To my custom hood
