hood choices?
Old Mar 27, 2006 | 01:57 PM
gator79's Avatar
gator79
Default hood choices?
I am changing the hood on my 71, it has a big block hood now but I am eliminating the wiper door and need a long style hood. I called vanacors and wanted to order the long style big block hood but the said I would have to modify the front cap area by the windshield and the only one that would work with out modification is the L 88 long style. they state it is 2 1/4 over stock height. I really do not want a hood that is too high. anyone have a picture of this hood? the stinger hood does not seem to be as high as the L 88, this might be an option. pics and advise please if you got em. thanks
Old Mar 27, 2006 | 02:06 PM
Scottys78's Avatar
Scottys78
I want to see this too
Old Mar 27, 2006 | 02:24 PM
crazywelder's Avatar
crazywelder
Call American Custom Industries and inquire about the RHF035L. This is a standard height L88 style hood specifically for 68-72 and eliminates the wiper door. Since the company you called mentioned a rear modification, it sounds like their long hood is molded to match '73 and later fenders at the rear. The above part number matches early fenders. ACI is a manufacturer and sells to most of the Vette parts houses, by direct and you might save $$$.
http://www.acivette.com/aci0013m.htm
Old Mar 27, 2006 | 02:29 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
personally I would go with the stinger hood. I am kinda pissed cause they only seel it in long style, Ian I like my wiper door ( actualy works trrouble free)
wish i could get one
tim
Old Mar 27, 2006 | 05:25 PM
Xakk's Avatar
Xakk
I've actually thought about putting an LT-1 long hood on my car, but I've never found a picture of what it would look like. I'm afraid that the combination of the longer hood plus the rubber bumber wouldn't look right.
Old Mar 27, 2006 | 08:17 PM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
If you do get rid of your stock B/B hood...how much are you looking to get and what color and shape is it in???
Old Mar 27, 2006 | 09:42 PM
gator79's Avatar
gator79
this is a picture of their L88 on a 71 at a local car show it was the 4 1/2 version. seems like it should be straighter across the back. if I remember the bottom of the windshield showed in the curves. what is the difference on the later C3's 73 on?
Old Mar 27, 2006 | 10:27 PM
pef427's Avatar
pef427
Do you have any complete pictures of this hood? Of entire car?
Old Mar 28, 2006 | 06:54 AM
gator79's Avatar
gator79
yep sure do
Old Mar 28, 2006 | 07:10 AM
crazywelder
The fenders are higher at the rear windshield area.
Old Mar 28, 2006 | 07:30 AM
gator79's Avatar
gator79
thanks. I was noticing that. that might be a pain to modify. still looking for pictures of long style hoods that eliminate the wiper door. anybody else have some?
Old Mar 28, 2006 | 08:15 PM
gator79's Avatar
gator79
ttt
Old Mar 28, 2006 | 08:19 PM
Corey_68's Avatar
Corey_68
My hood is from Vanacor but it is the SHORT L88 hood (stock L88 hight, NOT the high rise L88).
Old Mar 28, 2006 | 08:55 PM
gator79's Avatar
gator79
thanks Corey, that hood is starting to grow on me. how much clearance do you have under it? I may add fuel injection to my big block later and will need more clearance than the stock hoods offer.
I read somewhere the factory L 88 was 7/8 inch taller than the stock hood, so this hood is about 1 1/2 taller than the stock L 88 hood
Old Mar 30, 2006 | 02:21 PM
gator79's Avatar
gator79
Default found one
in my search for a hood I found one in my shop. I decided to go back with the factory hood and wiper door. the big block hood looks the best to me, I will just have to get used to the wiper door look.
thanks for the input
Old Mar 30, 2006 | 11:27 PM
GS977's Avatar
GS977
i need alot of clearance under my hood. my intake and 1050 dominator sit very high. whats the tallest L-88 hood availible. is the aci L-88 hood 4'' or 4 1/2'' or does vanacour make a 4'', or 4 1/2'' or higher L-88 hood.
Old Mar 31, 2006 | 01:12 PM
bryan27's Avatar
bryan27
call vanacor's corvette fiberglass. they are the nicest people. most of my car is made of their glass.
www.vanacorvette.com
To hood choices?
