Toughest drill bits?
Old Mar 29, 2006 | 10:34 PM
TonySinclair's Avatar
TonySinclair
Default Toughest drill bits?
I'm trying to drill out a bolt and have burned up three drill bits (appx. 1/8" +/-) without making nearly a scratch.
Can anyone recommend a type/brand of drill bit for this project? The bolt isn't hardened...
Old Mar 29, 2006 | 11:02 PM
majic1984's Avatar
majic1984
Dewalt cobalt bits... haven't broken one yet.
Old Mar 29, 2006 | 11:04 PM
JoeRags's Avatar
JoeRags
those are good bits... generally, the more $$$ you spend on a bit, the stronger it'll be. Try going up a size or two if you've got the room... smaller bits always break easy.
Old Mar 29, 2006 | 11:29 PM
Blue 74's Avatar
Blue 74
resharpen and use oil as a lube/coolant
Old Mar 29, 2006 | 11:36 PM
RHD '68 L89's Avatar
RHD '68 L89
By now the broken bolt is "heat treated" by the drilling. It will be hard to get started even with a good bit
Perseverence will get through the tough section to the "softer" material.
Old Mar 30, 2006 | 12:06 AM
TonySinclair
I used AeroKroil from the get-go...
Old Mar 30, 2006 | 07:35 AM
markdtn's Avatar
markdtn
My buddy swears by Snap-On bits. He says they are indestructable. I have had good luck with the DeWalt cobalt bits too.
Old Mar 30, 2006 | 08:16 AM
jester4's Avatar
jester4
Cobalt bits should do the trick, but because you have hardened the area already, you may want to try carbide. Carbide WILL drill through anything, but be careful it is very brittle (because the drill is so hard). Keep a steady hand and constant pressure. DO NOT re-grind carbide without a proper mask, carbide dust is entremely dangerous!.
Old Mar 30, 2006 | 12:08 PM
45ACP's Avatar
45ACP
Trust me on this one gentlemen, I know of what I speak...
When you are in a situation where a high speed steel drill bit -assuming is is not dull- cannot get the job done, go to your friendly local hardware store and buy a masonary drill bit.
They retain the toughness needed for pistol drill use via the steel shank, yet have the extreme hardness needed to cut the hard workpiece because of the carbide brazed onto the end.
Old Mar 30, 2006 | 03:02 PM
toolking's Avatar
toolking
I agree to a point (no pun intended) .... for this application because they are 2 flute drills most likeley will be too coarse to easily do a good job.
First choice carbide, second choice cobalt. I would suggest you find an industrial distributor locally that has a walkup counter (WW Grainger if available). They will most likely have what you need. Here's an example: http://www.grainger.com/Grainger/wwg...736796&ccitem=
Also get a split point drill as they will not "walk" as much. Use an oil lube (30 wt motor oil works) and above all be patient.
Old Mar 30, 2006 | 03:14 PM
NHvette's Avatar
NHvette
If possible ... torch it up cherry red and let it cool slowly.
This will de-temper the steel and make it softer.
Twisting off the head of a bolt will harden the area where it broke.
This is known as "work hardening" - the same thing that lets you
bend a coat hanger back and forth to break it ... the hardening
of the steel in the area where bent (worked) makes it more
brittle and allows it to crack. Hey, that materials science class
from college days finally paid off.
So, even a non-hardened bolt that twists the head off can
become hard - and not from rapid thermal or chemical treatments.
Drilling from the opposite end may work better, too.
If drilling ends up not working, you could try a diamond point on
a dremel, but that will be slow going. Something like the 7105 shown here:
http://www.mytoolstore.com/dremel/dmdbits.html
Good luck
Old Mar 30, 2006 | 03:29 PM
jester4's Avatar
jester4
Good suggestion on the split point. They may be slighty more expensive though.........
Just for future reference. To keep from burning up drills, instead of going high RPM and slowly pushing the drill (which will burn-up the edge), try a slower RPM and a more constant push on the drill. This is especially true for carbide. Carbide likes to be pushed, but always use your own judgment. Never exceed stability of the drill for a faster feed on the bit.
Old Mar 30, 2006 | 04:10 PM
fast idle's Avatar
fast idle
the dremmel diamond wheel is NOT for metal.and will not work.
Old Mar 30, 2006 | 07:17 PM
toolking's Avatar
toolking
The other thing i forgot to mention is that if you were using "hardware" drills intended for wood then they most likely were carbon steel or a very low grade High speed steel. Commercial grade High Speed steel drills should have easily handled this particularly if you didn't spin them too fast.
Old Mar 30, 2006 | 07:21 PM
68/70Vette's Avatar
68/70Vette
I used the diamond wheel to cut, among other things, the clips on my brake lines and also the clips and the gas lines themselves. However, all of this steel was soft. I used the wheel because it fit into the very small spaces that I was faced with. I didn't know the wheel was not for steel. Actually, it worked fine, but now that you've mentioned this, I did discover that the diamond wheel wasn't very durable. The diamond coating didn't "stick" on very long. At the price they cost, using these for steel (soft steel) does make them very expensive to use.
Old Mar 30, 2006 | 09:01 PM
TonySinclair
Thanks for the tips, all.
I guess my problem was drilling at high speed. I'll start over with a good bit on "slow".
Can't use a masonry bit as the bolt I'm drilling is only about 1/4" or so. Can't use a torch as this bolt is broken off in my door (mirror mount)...don't wanna melt the paint. Can't get it from the other side...cause the other side is inside the door.
Old Mar 30, 2006 | 10:19 PM
carl a's Avatar
carl a
i got masonary bits small as 3/16 come in the kit for tap cons(concrete anchors) as far as bits she bought me a drill doctor to sharper my old bits,,,works great,i go,slower for steel ,,,faster for alumn i believe alum is 1600rpm on a press,,,but dont qoute me its been years since shop class
To Toughest drill bits?
Old Mar 30, 2006 | 11:02 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Slow speed and cooling will work better (if the bolt is not hardened already from drilling at high speed).
try a small masonry drill - as funny as it may sound - these do work if the steel drill doesn't cut ....
You could also try a drill that is made for counterclockwise rotation, swith the drill to 'counterclockwise' and see if it turns the bolt. It may work.... good luck
Old Mar 31, 2006 | 09:04 AM
red topless gator's Avatar
red topless gator
Get a smaller masonry bit........LT
Old Mar 31, 2006 | 10:21 AM
BBShark's Avatar
BBShark
St. Jude Donor '05-'07
If you know someone that does production machine work, they may have a supply of carbide, 2-flute, stub ball end mills that need to be sharpened. The cost to sharpen these is usually more than the replacement cost so they are disposed of. I have used these in the past as drills and they make quick work of drilling just about anything.
