Shift pattern plate
Old Apr 1, 2006 | 11:00 AM
Jerry Curl's Avatar
Jerry Curl
Default Shift pattern plate
Um... How do you get out the old one to put in a new one?
Old Apr 1, 2006 | 11:09 AM
lvrpool32's Avatar
lvrpool32
There just glued on....use a knife to peel up and edge and away you go.
Nick
Old Apr 1, 2006 | 11:30 AM
Jerry Curl's Avatar
Jerry Curl
It looks like the plate is underneath another one that extends all the way to the top of the console plate. I assume that is glued on too?
Old Apr 1, 2006 | 11:59 AM
lvrpool32's Avatar
lvrpool32
Hmmm....I'm talking about the 4 speed "shift pattern" on the shifter plate....its probably 3.5" long and 2" wide.
Might be different on your year or are you talking about the 2 plastic sliders on an auto stick??
Old Apr 1, 2006 | 12:04 PM
Jerry Curl's Avatar
Jerry Curl
I have a 76.
On the back, it appears there is a longer plastic piece on top of the shift pattern plate. In order to get to the pattern plate, Im going to have to remove this top layer. But I see no screw holes.
To Shift pattern plate
