antenna conversion to power
Old Apr 1, 2006 | 11:02 AM
1Z87L8's Avatar
1Z87L8
Default antenna conversion to power
anyone ever convert their antenna to power?
if so what is involved for the conversion?
thanks
Old Apr 1, 2006 | 11:08 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I converted mine to electric only because I came across someone selling a power antenna in C3 for sale section. Easily done conversion. Just have to run a couple of wires. It also helped matters for me because I had the interior out in mine when I did the conversion. You can see the antenna at the end of my Timeline Video in my sig.
Old Apr 1, 2006 | 11:32 AM
1Z87L8's Avatar
1Z87L8
Eddie
thanks for the quick answer. i have to redo my interior anyway
so when its out i want to do the conversion not only for the clean lines
it offers but it will also help when i cover it.
thanks again
Old Apr 1, 2006 | 11:46 AM
Matt O's Avatar
Matt O
I did the same as Eddie 70 on my 69 vert. I ran one wire to ground and the other to a switch on the dash. I put the antenna up/down manually. It makes it easier to put the car cover on the car with the antenna down...
Old Apr 1, 2006 | 11:59 AM
ratflinger's Avatar
ratflinger
NCM Grand Opening Veteran
St. Jude Donor '11, '17
This brings up the question of whether or not one needs a Power Antenna Relay? I assume the relay keeps the antenna from sucking too much juice throught the stereo, but maybe this is no longer necessary. I've got both, but neither are installed yet.
Old Apr 1, 2006 | 12:56 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
I like to relay everything. I know on Pioneer stereos, the line for the antenna is not made to power it, but only to switch a relay.
To antenna conversion to power
