Frame Question
Old Apr 1, 2006 | 09:50 PM
tyrant's Avatar
tyrant
Default Frame Question
my '75 has been in storage for a few years now.i was changing the ps pump when i noticed some rot on the bottom of the front crossmember.there is also a small crack just on the bottom.how bad is this?
Old Apr 1, 2006 | 10:24 PM
big_G's Avatar
big_G
Pics...we need pics...
Old Apr 1, 2006 | 10:38 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
without pictures we can't make suggestions
Old Apr 1, 2006 | 11:20 PM
Tom73's Avatar
Tom73
If the rot is bad enough to see, no telling what is inside the frame that you cannot see.
Old Apr 2, 2006 | 11:34 AM
tyrant's Avatar
tyrant
i have some pics but i don't know how to post.
Old Apr 2, 2006 | 11:57 AM
tyrant's Avatar
tyrant
Default got pics
[IMG]
[IMG]frame2.jpg[/IMG][/IMG]
Old Apr 2, 2006 | 11:58 AM
tyrant's Avatar
tyrant
[IMG]
[/IMG]
Old Apr 2, 2006 | 12:11 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Somehow you kept ending up with a img tag between "erangic" and the file name when they should be around the whole URL.
Old Apr 2, 2006 | 12:56 PM
Twin_Turbo's Avatar
Twin_Turbo
if it's that bad there..it's probably much worse in areas where water collects,... the triangular gussets on the rear crossmember, near the #2 body mounts, underside of side frame rails.....
Old Apr 2, 2006 | 01:26 PM
tyrant's Avatar
tyrant
there is a lot of surface rust,but this seems to be the worse part i could be wrong.the only rust i noticed before i let it sit was the core support.should i not go any further on my repairs on it.
Old Apr 2, 2006 | 01:32 PM
Twin_Turbo's Avatar
Twin_Turbo
inspect the rest of the frame first and then when you know the overall condition start making a plan.
Old Apr 2, 2006 | 01:43 PM
tyrant's Avatar
tyrant
i'm poking around it now.there is some flaking in the areas you noted.i knocked off mabe 1/32 off the edge.can't tell if its dirt,rust or both.
Old Apr 3, 2006 | 10:05 AM
seventysixvette's Avatar
seventysixvette
Tyrant, I bumped a prior thread to the front you might find interesting. Look in the tech/performance area. Look for the thread:
Help frame issues!
.... Looks like mid 70's front crossmember/frame issues aren't uncommon.....John
Old Apr 3, 2006 | 06:43 PM
tyrant's Avatar
tyrant
Thanks so much.great info.
Old Apr 3, 2006 | 07:22 PM
JoeRags's Avatar
JoeRags
how long did you let this baby sit?
where is the crack you mentioned? cant seem to see it in the pics.
Old Apr 3, 2006 | 09:04 PM
tyrant's Avatar
tyrant
she spent two winters outside(very harsh winters).the crack runs up the center of the bottom of the crossmber.can't really see it in the pic.
To Frame Question
