Any good mods for a 1981 ?
Question is: Are there any relatively easy mods that can be done to the Motor or ECM unit that would boost a few extra ponies ? A quick gear change maybe ? What about pulling the 350 and dropping a 427 or 454 are they direct swaps or would Trannies need to be swapped as well ? Maybe just massaging the 350 to maybe a 383 Stroker, just to kill the annoying little Mustangs
Any comments would be welcome, she is my pride and joy and have always wanted a Vette, now I just want to show her off and enjoy the hell out of her !! Thanks for listening !
Toss the freakin' computer first........(and if you toss the 'puter you must replace the distributor, and the carb).
Desmog.......
Cut out the cat and go true dual exhaust........
New intake manifold (Edelbrock performer).........
New MSD distributor........
New Carb...........
This wil get you about 30-50hp.
Now, you can go one of two ways from this point.
Left Path: Pull the motor, have it bored and honed, and have it rebuilt a 383 stroker, or, a 355 or 357 with some nice heads and cam!! 400 hp in these light cars is a blast!! Or get a crate, and set you original motor aside.
Right Path: Just add some new better flowing heads, intake manifold, and a new cam. Don't have to pull the motor for this one!! You can probably get up to over 300 hp from doing this, if your bottom end is in good shape.
Have fun.......an 81 will probably never be much of a collector, so mod it as you wish! But........save all your original parts, box them up, and maybe oneday you will have a reason to return her to original condition.
Good luck!!
I keeping all of the original parts, boxed up, including the motor block! One of my heads wasn't original, thus the added reason for the change.
Doing all the work myself, with some help. Believe it or not, all I new how to do to the car a year ago was change the oil.
Two books I highly recommend: Both by David Vizard (the wizard of small blocks). You can get these at most large bookstores..
"How to rebuild your Small Block Chevy". and "How to Build Max Performance Small Blocks on a Budget".
Both excellent, and easy to read and understand.
Have fun, jump in, and feel the power!!
I will again, very soon!!
The deeper 1st gear and low cruising RPMs change the whole personality of the car. Do a search on these trannys and you'll find lots of info.
Actually, I almost did that.......throttle stuck under the air cleaner after I put a new carb on!! Found out real quick that a new breather was required!!
Wasn't thinking clear enough to just turn the damn key off, so I threw it up into neutral real quick, motor readlined, backfired, and I heard "clank, clank, clank......" Thought oh chit, just grenaded the tranny. Ended up breaking a 1/2 shaft!!
Talk about bad luck. I think I should sell it and start over!
I've had it now for a year and 3 months, and the following has happened:
Had a flat and went to change it. Could not get the lock to open on the spare cover. Cut/Beat the lock off.......spare was dry rotted.
When I changed out the distrib. and carb, it started overheating and never ran the same.
When I was testing the new changes, throttle stuck, and broke 1/2 shaft.
Burnt up the brand new spark plug wires. (They were touching the exhaust manifold.)
Had to replace right rear bearing (that was a bugger).
Was going to a cruise-in, and overheated on the highway when the heater hose broke!!
Bought 750 cfm carb, it was to much. Bought 600 cfm carb, it was still to much for the weak motor.
Bought new crate to compensate for the weak motor, installed, and blew it up on a 1/2 mile drive.
Yea, you can say I have had a few adventures......
a tank undercarriage should hold up ok.
I was thinkin' about one of those good ole Plymouth Fury III's w/ the 383 in them. Man, that thing was a tank, that would fly. My dad had one, but older brother totalled it at 16 yrs. of age. Never got to drive it legally....lol.....
