Vacuum Storage Tank
Old Apr 5, 2006 | 02:50 PM
markbett's Avatar
markbett
Default Vacuum Storage Tank
I know I should be in the parts area but,,, I just found a hole in my vacuum storage tank and of course, nobody sells these things Has anyone used a tank from another model year or modified something to work? I got a '69.
Old Apr 5, 2006 | 07:36 PM
Corvette ED's Avatar
Corvette ED
From: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
I would repair the tank with epoxy.
Old Apr 5, 2006 | 07:44 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I used a fiberglass repair kit, just laid a small section and sanded it smooth.
Old Apr 5, 2006 | 08:40 PM
markdtn's Avatar
markdtn
I used an 81 tank. It's like a #10 can with a few tubes sticking out. Still available new from GM a few years back.
Old Apr 5, 2006 | 10:42 PM
driver68's Avatar
driver68
i ended up bypassing my storage tank altogether. of course, now i have to turn the lights off BEFORE i turn the engine off!
Old Apr 5, 2006 | 10:52 PM
Edzred72's Avatar
Edzred72
No one reproduces the originals so a used one is your only option. Try to repair it where it sits (if you can) cause they are a pain to remove. Especially if you have pwr brakes & 4 speed.
Eddie
To Vacuum Storage Tank
