old but still funny
Old Apr 5, 2006 | 03:02 PM
panchop's Avatar
panchop
Default old but still funny
anyone who works on their corvette should recognize these necesery tools.
( I said corvette, kay, )
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and
flings your beer can across the room, smashing it against that freshly restored corvette you where working on.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints
and hard-earned guitar calluses from fingers in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes until you die of old age.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
HACKSAW: One of a family of cutting tools built on the Ouija board principle. It transforms human energy into a crooked, unpredictable
motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to further round off bolt heads. If nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease
inside the wheel hub you want the bearing race out of.
WHITWORTH SOCKETS: Once used for working on older British cars and motorcycles, they are now used mainly for impersonating that 9/16 or 1/2 socket you've been searching for the last 15 minutes.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack
handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward off of a trapped hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters and wire wheel wires.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known drill bit that snaps off in bolt holes you couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile strength on everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large prybar that inexplicably has an accurately machined screwdriver tip on the end
opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a drop light, it is a good source of vitamin D, "the sunshine
vitamin," which is not otherwise found under cars at night. Health benefits aside, its main purpose is to consume 40-watt light bulbs at about the
same rate that 105-mm howitzer shells might be used during, say, the first few hours of the Battle of the Bulge. More often dark than light, its
name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids and for opening old-style paper-and-tin oil cans and splashing
oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a coal- burning power plant 200 miles away and transforms it into compressed air that travels by hose to a Chicago Pneumatic impact wrench that grips rusty bolts which were last over tightened 50 years ago by someone at Chevrolet , and neatly rounds off their heads.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive
parts not far from the object we are trying to hit.
MECHANIC'S KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on
contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
DAMMIT TOOL: Any handy tool that you grab and throw across the garage while yelling "DAMMIT" at the top of your lungs. It is also the next
tool that you will need.
EXPLETIVE: A balm, also referred to as mechanic's lube, usually applied verbally in hindsight, which somehow eases those pains and indignities following our every deficiency in foresight.
Old Apr 5, 2006 | 05:03 PM
694speed350's Avatar
694speed350
as far as the trouble light make sure it wasn't made by lucas.
Old Apr 5, 2006 | 07:55 PM
76project's Avatar
76project
Hey, I have one of those hose cutters, works just like it says.
Old Apr 5, 2006 | 08:55 PM
carhound's Avatar
carhound
Those are great! Never heard them before.
Old Apr 5, 2006 | 09:00 PM
mkflanagan's Avatar
mkflanagan
Also used for burning the rubber bushings out of the rear strut rods installed 30 years ago at Chevrolet
Old Apr 8, 2006 | 02:08 AM
danno12345's Avatar
danno12345
Yup, I've got a few of those in my garage...
Old Apr 8, 2006 | 03:30 AM
applevette's Avatar
applevette
Thats some funny chit! Gonna get me in trouble at work for laughing so hard!
Old Apr 8, 2006 | 08:33 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Old Apr 8, 2006 | 09:37 AM
corvette-pilot's Avatar
corvette-pilot
Old Apr 8, 2006 | 09:47 AM
Mallett Z's Avatar
Mallett Z
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
i use the dammit tool all the time!! lol thats the best one!!
Old Apr 8, 2006 | 04:09 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Awesome!
Old Apr 8, 2006 | 04:20 PM
Grease Monkey's Avatar
Grease Monkey
From: Hampton, VA Yea, i'm a redneck... but you love it
Cruise-In 8-9 Veteran
aka/Trunk Monkey/Banned For Life/Corvette For Life
Old Apr 8, 2006 | 04:22 PM
VQT88Vette's Avatar
VQT88Vette
Old Apr 8, 2006 | 05:20 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Lucas: prince of darkness ( I used to ride Triumph motorcycles).
This is a great thread
Old Apr 8, 2006 | 08:34 PM
80sRule's Avatar
80sRule
Look at my user name, and deny that I know Lucas.
GT6
Old Apr 8, 2006 | 09:03 PM
Dobermann's Avatar
Dobermann
Old Apr 8, 2006 | 11:50 PM
Z51JEFF's Avatar
Z51JEFF
Peter Egan who writes for one of the big car mags did something like this years ago.I was on brake at work one night laughing my *** off as I read it.
To old but still funny
