Engine number on 72 S/B
Old Apr 6, 2006 | 06:25 AM
LS104's Avatar
LS104
Default Engine number on 72 S/B
Can someone tell me please how many digits should be in the number on the block. ( Im looking to buy ) Owner said original block, but looks to be re stamped. How do i tell the difference.
Old Apr 6, 2006 | 08:16 AM
chevylit's Avatar
chevylit
I think there should be 2 sets of stampings on pad.One is engine
assembly stamping and other is VIN stamping. Small block should be
" V" then 4 numbers for month and day assem. then 3 letters for
engine type. The VIN should start with 1 then 2 then S then final
6 digits of cars VIN. Someone else can probably do a better job of
explaining but this may help You.
Old Apr 6, 2006 | 08:33 AM
MidShark's Avatar
MidShark
Should look similar to this (this is a '71) . The fuel line is covering the assembly date. The last 6 numbers of the set on the left should match the car's vin as stated.
Old Apr 6, 2006 | 10:03 AM
LS104's Avatar
LS104
Thanks guys, the one i looked at did not look like this!
it had 2 rows of # and all the same size
Old Apr 6, 2006 | 12:06 PM
72LS1Vette's Avatar
72LS1Vette
The 72 that we just purchased has the same type of stamping as seen in this picture.
Rick B.
To Engine number on 72 S/B
