Spicer U joints Help
Old Apr 6, 2006 | 05:42 PM
alotaball's Avatar
alotaball
Default Spicer U joints Help
about to buy some new u joints... want to go with the spicers .. anyone know where to buy them for the best price .. online ??? Thanks
Old Apr 6, 2006 | 06:17 PM
Red 69's Avatar
Red 69
Try Here
http://cgi.ebay.com/Half-Shaft-Spice...QQcmdZViewItem
Old Apr 6, 2006 | 07:48 PM
BKbroiler's Avatar
BKbroiler
I got mine from fastcorvette.com, although I have seen some negative press about them here lately. I had no problems.
Old Apr 6, 2006 | 11:13 PM
b71vette's Avatar
b71vette
Look in the Yellow Pages under DriveShaft Service, locally mine were about $17 each. Also I would recommend taking the halfshafts in and have the shop swap them out and balance shaft.
The Spicers came highly recommended by the local shop, the only issue they have is the black dust cap has a tendency to crack while installing onto shaft, in which case you need to remove the u-joint again and replace the black cap. Local shop showed me a whole box of the dust caps which had cracked on them, but without a doubt they said they were the strongest and wouldn't recommend anything else.
Old Apr 6, 2006 | 11:29 PM
RobRace10's Avatar
RobRace10
Since the topic of U-joints came up, can some answer this?
Are the half shaft and drive shaft U-joints the same?
Old Apr 7, 2006 | 12:00 AM
b71vette's Avatar
b71vette
No, they are different sizes.
Old Apr 7, 2006 | 12:10 AM
alotaball's Avatar
alotaball
Thanks for the info .. yeah maybe ill just bring them down to a driveline shop and have them install .. that way they have to make sure not to break the dust seal
To Spicer U joints Help
