Got the pipes
Apr 6, 2006 | 11:07 PM
Got the pipes
Apr 6, 2006 | 11:59 PM
Looks like you did ok, congrats
Apr 7, 2006 | 01:27 AM
are you going to add a cross-over ??
Apr 7, 2006 | 04:09 AM
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
There's a lot of oil stains on your driveway.
Apr 7, 2006 | 06:36 AM
Comp-I'm not the smartest mechanic around not sure what a crossover is
Jughead-Thats the seller's driveway..thank god.
Sixfooter- thanks was hoping I did.
Apr 7, 2006 | 09:08 AM
cross-over connect's the two side's and help's balance the ex. pulse's.
helps the low end power and a little with noise
Apr 7, 2006 | 04:24 PM
Wasn't planning on a crossover....can you get a kit to do it or just cut holes and weld a pipe in....
Apr 7, 2006 | 04:32 PM
Quote:
Yes you can get one from Jegs or Summit Racing. I would put one in and I think you got a good deal on the pipes. I would clean them up as best as you can (get the rust off) and paint them w/high heat engine paint black. G/L & let us all know how it sounds.
Apr 7, 2006 | 05:37 PM
Thanks......Is this what I'm looking for?
Apr 7, 2006 | 05:53 PM
2018 C2 of Year Winner
X Pipe seems to flow better and reduce popping on decelleration. At least that is what I found on my C-5
Apr 7, 2006 | 07:56 PM
That's it. comes with two straight pipes & two bent pipes.
Apr 8, 2006 | 01:08 AM
