I believe you have to fill it when it is fully retracted.and add as much as it will take, but I would also strongly suggest that you repair any leaks or any bad seals first.
Later,
Sly
Basicly what happened is the cylinder was stored upside down and some fluid leaked out around the shaft. The jack still works fine but I want to top it off.
