make me happy
Old Apr 8, 2006 | 06:52 PM
brdd's Avatar
brdd
From: Minnesota in the summer, Las Vegas in the winter
Default make me happy
Within a week or so I will be putting my dash back together. Currently I have the speedo and tach out, the steering wheel off (but not the column), all dash pads and the gauge bezel, and the console. Its a mess.....
What I am looking for are LOTS of pictures of dashes like this. Any step-by-step advice will also be appreciated. Anyone who has changed color in dash and column has gone this far.
By the way, I finished my seats today. They look great and only took a couple of afternoons. Anyone who wants to come put my dash together, I will put your seat covers on for you.......
Old Apr 9, 2006 | 01:09 PM
brdd's Avatar
brdd
Doesn't anyone have pictures of their ripped-apart dashes? And information as to how they put theirs back together? Maybe you missed something and I should know about it. C'mon.......
Old Apr 9, 2006 | 03:09 PM
gator79's Avatar
gator79
Default you asked for it
this probably wont help but this is my 71 vert dash
Old Apr 9, 2006 | 04:54 PM
brdd's Avatar
brdd
That's exactly the kind of pictures I'm looking for. Thanks much for taking the time to help out an old vette restorer who doesn't know what he's doing....
Old Apr 9, 2006 | 05:24 PM
Tewski's Avatar
Tewski
Veteran: Marine Corps
St. Jude Donor '06 thru'17, '23-'26
Different direction than the previous one, this is out of my 76, not sure if it will help with your 72.
Old Apr 9, 2006 | 10:20 PM
c69vete's Avatar
c69vete
Finalist 2021 C3 of the Year - Modified
2017 C3 of Year Finalist
Cruise-In VIII Veteran
St. Jude Donor '07
Default 69 dash
Pics of recent removal of 69 dash. I installed the left side first. Hardest part is connecting the speedo and tach cables. next is pluging in all of the light bulb sockets. Right side is a piece of cake. Then guage cluster and console and p brake cover. Good luck.
Old Apr 10, 2006 | 12:18 AM
Z-man's Avatar
Z-man
Do you still have the pictures that you took when you took the dash apart? (You *did* take pictures, right?) Maybe you could get some guidance that way...
Old Apr 10, 2006 | 12:52 AM
gator79's Avatar
gator79
I see your glasses on the dash must be bifocals, mine make me crazy trying to work under a dash. they have to come off
Old Apr 10, 2006 | 07:38 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Does this help a bit more, I left the pictures big for you this is a 72 stripped.
This is all new gauges & dash installed
Just another view
Old Apr 10, 2006 | 11:06 AM
brdd's Avatar
brdd
This kind of reference is just what I was looking for. This coming weekend (if my parts show up) my son and I will begin putting our dash back together. Your efforts are appreciated........
Old Apr 10, 2006 | 12:32 PM
NHvette's Avatar
NHvette
... just pulled my drivers dash out ... again. I just wasn't happy with
my door alignment - and needed to get at the hinge bolts easily.
Best advice I can give is to not try installing the drivers dash
and squeeze it over the steering column. The lower lip will snap.
Lowering the column (dropped to floor) also lets you connect all the
lightbulbs/harnesses/speedo cables while tipped forward and you can see.
Mine is 75 - similar to all others posted. Later years will differ (78-up ?)
Old Apr 10, 2006 | 02:38 PM
bashcraft's Avatar
bashcraft
I need to start putting mine back together too. I'm guessing that it would be easier to put the dash panels in and wire everything before the top dash pad goes in?
Old Apr 10, 2006 | 07:18 PM
brdd's Avatar
brdd
I admit I'm a little nervous about dropping the column. I've never touched anything like that. I even painted it intact in the dash. We had a devil of a time getting the lower dash out but we did it. I know that will be the toughest part to do. I don't look forward to putting the gauge area back together. We didn't take any gauges out but there sure is a lot of stuff there...........
Can someone talk me through dropping the column?
Old Apr 10, 2006 | 07:20 PM
brdd's Avatar
brdd
.....very good question............
Old Apr 10, 2006 | 08:43 PM
Tewski's Avatar
Tewski
I put the instrument cluster back in before installing the dash pad, it made it much easier to hook up the lights and everything. I've attached links to Jim Shea's steering column papers, he gives detailed written instructions for dropping the column
Paper #1
http://jimshea.corvettefaq.com/wp-co...&R1-27JA06.doc
Paper #2
http://jimshea.corvettefaq.com/wp-co...2-20JA2006.doc
Old Apr 11, 2006 | 11:25 AM
brdd's Avatar
brdd
The article makes it clear not to let the steering column just hang by its own weight. But I don't want to take it out; I just want to lower it some to I can get the lower dash panel back and install the speedo, tach and lights correctly. Can someone tell me if it is okay to drop it a couple of inches with support?
To make me happy
