1978 L82 ?
Old Apr 9, 2006 | 12:41 PM
78SA's Avatar
78SA
Default 1978 L82 ?
So what is the difference btwn a 78 L48 & L82 motor besides a little more compression, aluminum manifold, air cleaner & HP? .. i heard steel crank & 4 bolt mains is this true and did they have different heads ? thanks
Old Apr 9, 2006 | 03:23 PM
79MakoL82's Avatar
79MakoL82
L82 had 4 bolt mains, forged steel crank and forged flat top pistons. A very stout bottom end. It also had different heads and cam with larger valves, and screw in studs. Not sure if the chamber volume or runner volume was different though.
Old Apr 9, 2006 | 03:53 PM
Tom73's Avatar
Tom73
L82 has much stronger bottom end as mentioned above, plus big valve heads and a much hotter cam.
Old Apr 9, 2006 | 04:16 PM
78SA's Avatar
78SA
Interesting.. thanks guys
To 1978 L82 ?
