engine starting
Old Apr 10, 2006 | 02:19 AM
lbchopperscott's Avatar
lbchopperscott
4th Gear
Default engine starting
Hi everyone- what s the best way to get an old BB to life after it has been sitting a few years? I know that the motor was running before it went into garage hibernation, but it hasn't been started or ran in probably 4 years.. any advice?
thanks
scott in long beach ca
Old Apr 10, 2006 | 07:21 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Change the oil & filter, remove the spark plugs, shoot a tiny bit of oil into each cyclinder. Once you have everything ready, remove the coil wire so it won't fire. Turn the engine over a few times allowing it to get thing moving. Re-install coil wire, fire engine.
Old Apr 10, 2006 | 09:54 AM
sxr6's Avatar
sxr6
If it were mine (I wish ) I would also pull the distributor & drive the oil pump for a bit to make sure oil is run thru the motor.
Old Apr 10, 2006 | 04:42 PM
ksbunting's Avatar
ksbunting
I agree with SXR6.
I spun the oil pump over with an electric drill until I saw oil pressure reading on the gauges and that way I know I had oil pressure and wasn't starting up dry.
To engine starting
