Shell 94 octane
Old Apr 10, 2006 | 10:46 AM
houstonvett's Avatar
houstonvett
St. Jude Donor '09, '24
Default Shell 94 octane
Here in the Houston area have been buying premium gas for almost $3 a gallon. I have noticed the octane rate is now 94 for Shell V formula. Anyone else notice the octane increase in their part of the country? At $3 a gallon glad Shell made some improvement to the gas houstonvett
Old Apr 10, 2006 | 10:58 AM
bbfirebird's Avatar
bbfirebird
Still stuck with 91 premium in Phoenix AZ.
Old Apr 10, 2006 | 11:19 AM
pws69's Avatar
pws69
And you believe this because.....
Old Apr 10, 2006 | 12:23 PM
Mike Ward's Avatar
Mike Ward
Why would you need 94 octane? Most C3 Corvettes were made to run on regular.
Old Apr 10, 2006 | 04:10 PM
Biggus Blockus's Avatar
Biggus Blockus
I'll bet it's no real improvement. I'll bet they started mixing the gas with MTBE or Ethanol, which might raise the octane, but it's actually CHEAPER gas that they are charging you the same or more for.
Bastages. Too bad the government is doing nothing about the riduculous profits the oil companies are making. Why, becasue they are all in their pocket.
Old Apr 10, 2006 | 05:29 PM
Kalway's Avatar
Kalway
Solution: Stop voting for the DNC and GOP, I'd rather have the green party, at this point. I always vote libertarian, though.
Still 91 octane here in CA, remember octane ratings change with altitude and formula based on geography. The 91 here is actually probably about 92 or 93, but according to the math it's 91.
Old Apr 10, 2006 | 11:08 PM
73, Dark Blue 454's Avatar
73, Dark Blue 454
Big oil makes about $.10 a gallon,..not out of line. Do you know what your government(s) makes per gallon?
Old Apr 11, 2006 | 12:13 AM
JoeRags's Avatar
JoeRags
$2.90??
Old Apr 11, 2006 | 07:44 AM
houstonvett
Think the Feds make about $.67 a gallon in taxes and the state gets a cut here too, houstonvett
Old Apr 11, 2006 | 02:48 PM
CGGorman's Avatar
CGGorman
Fine. How much does it cost produce a gallon. One number means nothing without the other. If it costs them $0.10 to produce a gallon, then a %100 profit margin is out of line. If it costs them $1.00 to produce a gallon, then a %10 margin is perfectly acceptable.
What kind of margins do most huge corporations (thinking GM/FORD here) enjoy?
As far as taxes, we all know THEY suck and gouge...and suck, then gouge some more.
Old Apr 11, 2006 | 03:01 PM
rdog's Avatar
rdog
Default 94 Octane
We have 92 octane here in Washington. Still not enough for the 427/454 original big blocks. I have kept mine original specs from the factory in 68. Have to mix 110 octane with the pump gas to keep my 427 from pinging and lugging. Mix about 3 to four gallons of 110 octane with the premium pump gas (92) and it works OK then. 110 octane around here is about $7.00 a gallon. Luckily there is a custom shop for muscle cars and corvettes nearby where I buy mine. Gets expensive when you want to go on a cruise. Always keep two 5 gallon cans handy filled with 110 octane to mix.
Old Apr 11, 2006 | 03:16 PM
IMA 66's Avatar
IMA 66
we used to have 94 at our Sunoco's around here in Delaware but they all dropped to 93. Plus the station i usually go to on the way to work doesn't seem to sell 93 either. Everytime i select it it tells me invalid grade and i have to put 91 and i know everyone says it doesn't matter especially in a low compression 74 but when i put that crap in and get into her on a warm day you can heare her pinging in the upper rpm range all is ok now though as i found another Sunoco with 93 on tap
Old Apr 11, 2006 | 03:19 PM
ccs96's Avatar
ccs96
St. Jude Donor 06-'07
Let's punish the oil companies ...by letting the government tax the profit, because the government REALLY knows how to spend it!!!
Come on, the oil companies make $$, so what, that's what companies do, and if you don't want to add to their profits, you can ride a bike. That's my .02 (no profit included) (& I don't work for an oil company).
Old Apr 11, 2006 | 03:22 PM
79MakoL82's Avatar
79MakoL82
My Vette has never like Shell for some reason. I always got run on using the premium Shell, but just about any other premium works fine.
Old Apr 11, 2006 | 03:32 PM
enkeivette's Avatar
enkeivette
Phhh... it's not like our government has the responsibility to break up monopolies!
To Shell 94 octane
