Luggage Rack Question
Old Apr 10, 2006 | 02:38 PM
wnmech's Avatar
wnmech
Default Luggage Rack Question
I found out from my build sheet that my 77 had a V65 build sheet option. I am stripping my car down to glass and I found where the holes were glassed over. My question is I want to put a new rack back on the car. Are they all pretty much standard to where if I reopen up the factory holes will the aftermarket chrome rack use the same holes or should I leave them filled and get the new rack and try aligning it with the old plugged holes?
Old Apr 10, 2006 | 03:22 PM
luerja's Avatar
luerja
Wait and get your new one first...Luggage Racks were a dealer installed option and they did vary in mounting hole configuration.
You may also want to look at the options for the luggage racks too. Some have studs on the rack and were used to hold the T-Top mounting brackets so you can pull your t-tops off and throw them on the luggage rack really easy and hold them down with the strap.
Jim
Old Apr 10, 2006 | 08:13 PM
docmow's Avatar
docmow
2021 C5 of the Year Finalist - Unmodified
make sure you order the ones with the pins it was the standard one
in 1977 with that option
Old Apr 10, 2006 | 08:24 PM
Rich427's Avatar
Rich427
I don't know much about 77 but my 69 has a factory rack. At least when the 69s were built, if you ordered a luggage rack, it was on the build sheet and on the window stick, but it was in a box in side the car. The dealer installed it after it was delivered from the factory.
My original rack started to show some surface pitting, so I looked for a reproduction. I looked at chrome and stainless racks but I never found one that fit exactly. When I would measure from one mounting point to another, it was always off by 1/4 -3/8 of an inch, so I knew they would not fit my mounting holes. So, I pulled my original luggage rack off and took it to Librandi's In Harrisburg and had them re-chrome my original rack. Best thing I ever did! When I got it back, the holes lined up perfectly. Plus the chrome was better than the reproduction racks.
So, don't touch the holes until you find the rack that you want. After you get the rack, put it together and then lay it out on the rear deck. Mark the location of the new mounting points then pull the rack off. I would then do some sanity measurements to ensure that you have it perfectly centered.
Good luck!
Old Apr 10, 2006 | 10:46 PM
79 vette head's Avatar
79 vette head
St. Jude Donor '10
leave it off..... imo that was the uglyest thing ever put on a vette. i just don't care for the luggage rack look
Old Apr 11, 2006 | 08:01 AM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
77 was the first year the rack was installed at the factory should be an 8 hole rack.
The exterior luggage rack became an official option (RPO V54) and was a dealer installed option prior to the 1977 model year.
More info.
http://corvetteactioncenter.com/spec...977/index.html
Old Apr 11, 2006 | 08:44 AM
moosie982's Avatar
moosie982
Yeah, along with rear window louvers Peace,,,Moosie
To Luggage Rack Question
