parts washer
Old Apr 14, 2006 | 05:11 PM
AirTrafficController's Avatar
Default parts washer
I need either a very small parts washer, or a parts washer fluid can with basket. I just have a bunch of small parts, mostly bolts, that need degreasing. Any suggestions? Thank you. Mark
Old Apr 14, 2006 | 05:13 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
http://www.harborfreight.com/cpi/cta...emnumber=35740
Old Apr 14, 2006 | 06:12 PM
JoeRags's Avatar
JoeRags
problem is, if you get a bigger one, you have to think about disposing of the 20 gallons of solvent when your done with it.... I used to have a large one, passed it on when I was done with all the real nitty gritty work. now its his problem.
Old Apr 14, 2006 | 06:18 PM
I'm thinking about getting that $39 one from Harbor Freight, but the manual for it says they recommend a non-solvent based cleaner. Anyone have experience using the biodegradable liquids ?
Old Apr 14, 2006 | 09:10 PM
greenice's Avatar
greenice
Simple Green works for us. We have the cleaner above from harbor freight. Fill with water, use simple green and brushes to wash parts. Wait a week or two for solids to separate from water. Drain water and down drain pipe (just like washing hands). Solids at bottom get the kitty litter treatment. Dump in some kitty litter, smear around (using gloves) dump into box and out with trash.
Old Apr 14, 2006 | 09:29 PM
gator79's Avatar
gator79
parts washing brush from your local parts house and 2 gallons of gas in a 5 gallon bucket with a lid so the most expensive part of this does not evaporate
Old Apr 14, 2006 | 10:18 PM
Greg in VA's Avatar
Greg in VA
Advance Auto sells a 1 gallon bucket that is full of Carb cleaner and it has a basket in it to hold the parts while they soak. It's metal and has a metal top so you can close it up and keep it for next time when your finished.
Greg in Va
Old Apr 15, 2006 | 10:45 AM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Purple Power cleaner cheap and biodegradable and works great.
Old Apr 15, 2006 | 12:10 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
Greg in Va
Don't get any of this on you though.
Old Apr 15, 2006 | 04:31 PM
Where can I buy this? I went to the company website, and it says to use purple power ultra for metals. Thanks - Mark
Old Apr 15, 2006 | 04:54 PM
Yellow73SB's Avatar
Yellow73SB
St. Jude Donor '07
I think sams has it. Usually on there site they have something that list the distributors.
Old Apr 15, 2006 | 06:33 PM
ksbunting's Avatar
ksbunting
My small parts washer is a 1 pound coffee can with a smaller can inside.
The smaller can has holes in it around the bottom so the fluid drains out. I use gasoline and keep it on my bench to wash bolts and small stuff. I know, the EPA doesn't like it but it works.
Drop the stuff into the small can, submerge it in the gasoline, let it sit a little while, lift out the small can and let the gas drain back into the large can and remove the cleaned parts.
Kurt
Old Apr 15, 2006 | 10:44 PM
vref's Avatar
vref
Napa sells solvent by the gallon if you bring your own gas can. $7 a gallon or so, then get aluminum catering pans from Sams. Clean you parts, the problem is getting rid of the solvent after its dirty. I still have about 3 gallons of it stored till I find a enviroment friendly way to dispose of it.
Old Apr 16, 2006 | 04:53 PM
BLUSHRK's Avatar
BLUSHRK
Kurt
what's the next step if you are gonna paint those small parts? What would you reccommend after the gas soak? Simple Green? Dish soap?
Old Apr 16, 2006 | 06:13 PM
ksbunting's Avatar
ksbunting
I have not had good luck with washing with soap and water as there always seems to be some moisture trapped no matter how hard I try and then it becomes rust. I use Eastwoods pre paint prep whihc is called "Pre" and comes in spray cans. Often, I have just painted after the gas dries off without doing anything.
Kurt
Old Apr 16, 2006 | 06:24 PM
JPhil's Avatar
JPhil
For pre-paint prep, go get some lacquer thinner and wash and wipe until the paper towels stay clean.
To parts washer
