Removed Trailing Arms...Dread the install...
Old Apr 14, 2006 | 11:17 PM
mbeeman350's Avatar
mbeeman350
St. Jude Donor '03-'05-'06-'07-'09
Default Removed Trailing Arms...Dread the install...
How in the world do you get the bolts back in????? it was a nitch to get them out....
Old Apr 14, 2006 | 11:20 PM
jdmick's Avatar
jdmick
I picked up a super long needle nose pliers at Harbor Freight for under $10. Worked like a charm. Not sure what I'll ever use it for again though.
Old Apr 14, 2006 | 11:45 PM
swtato's Avatar
swtato
St. Jude Donor '05
tie fishing line through the cotter pin hole at the ned of the bolt and pull them through.
Old Apr 14, 2006 | 11:53 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
The long needle nose pliers worked on all 3 of my Vettes! The left side is a real PITA. I had to slide the bolt in head first behind the brake lines the moved the threads to the hole. I got both bolts started in the holed before I attempted to put the TA in place.
Old Apr 15, 2006 | 12:35 AM
SIXFOOTER's Avatar
SIXFOOTER
nitch?
Old Apr 15, 2006 | 01:19 AM
myoriginal77's Avatar
myoriginal77
heh - heh ... you said nitch ....
Old Apr 15, 2006 | 08:44 AM
mbeeman350's Avatar
mbeeman350
We can't cuss ??? right
Old Apr 15, 2006 | 08:54 AM
NC C3's Avatar
NC C3
works like a charm!!
Old Apr 15, 2006 | 12:00 PM
Muddywaters's Avatar
Muddywaters
This is what I used too...worked like a charm... I believe I set the TA on a block...
Old Apr 15, 2006 | 05:30 PM
SwedeAWACS's Avatar
SwedeAWACS
fishing line!
To Removed Trailing Arms...Dread the install...
