HD Differential Side Yokes?
Old Apr 16, 2006 | 08:55 PM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Default HD Differential Side Yokes?
Is The Superior HD worthe the extra $$85? I don't plan on racing.(much)
Old Apr 16, 2006 | 09:05 PM
corvgreg's Avatar
corvgreg
Emerging Vendor
You also need to factor in the 4 caps needed for the threaded style, I wouldn't worry unless you are beating on it hard. Just have good ujoints like spicers.
Old Apr 17, 2006 | 04:38 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Then I found these too. The "superior" version above looks "meatier."
63-79 Stub Axles
These are NEW GM differential carrier axle yokes. The HD threaded units are GM part # 3872922, while the U bolt style is GM part # 14016436.
$126 Part # D081
(One Threaded Stub Axle)
Old Apr 17, 2006 | 06:42 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
Still another at Ecklers, this one includes caps bolts & springs.
Old Apr 17, 2006 | 07:59 AM
GTR1999's Avatar
GTR1999
I use the standard hardened tip yokes that lonestar fabs up. The tip is harder then stock and should be fine for daily and strip use. If you're going to torque them enough to twist them you're going to have other failures too.
Old Apr 17, 2006 | 08:48 AM
comp's Avatar
comp
good info
To HD Differential Side Yokes?
